Prusa MK3S+
Revision as of 23:44, 28 September 2024 by Pearlgreymusic (talk | contribs)
Apollo
Status Active
Manufacturer Prusa
Model i3 MK3S+ & Pi 3B
Nozzle Size 0.4mm
Nozzle Count 1
Filament Size 1.75mm
Max Bed Temperature 122C
Max Nozzle Temperature 295C
Max Print Speed 100mm/s
Extruder Type Direct
Manual Unknown
Hermes
Status Active
Manufacturer Prusa
Model i3 MK3S+ & Pi 4B
Nozzle Size 0.4mm
Nozzle Count 1
Manual Unknown
Sunwukong
Status Active
Manufacturer Prusa
Nozzle Size 0.4mm
Nozzle Count 1
Manual Unknown
The printers are controllable over Octoprint, which you can use the web browser or an app to connect to while on the ASMBLY network. You cannot access these machines from home. Tasks such as preheating and filament changes can be done via the built-in panel on the front bottom of the printer. The Octoprint configuration is the standard OctoPi installation, consisting of the Raspberry Pi 3 or 4 being attached to the back of the printer frame, connected via USB to the printer and via Ethernet to the ASMBLY network (WiFi connection from the Pi to the network is currently unstable), with the OctoPi 1.0.0 (build 2023.10.09.151442) stable image installed on the Pi. In an attempt to keep the printers as easily serviced and maintained, we are trying to keep the installation as standard as possible. More documentation about OctoPi can be found here. Files for printing replacement Pi 3B and Pi 4B cases can be found at the page bottom.
Revo Hotend Upgrade
All three Prusa i3 mk3s+ printers have been upgraded with the E3D Revo hotend (from the stock E3D V6). They are all equipped with the 0.4mm abrasion-resistance ObXidian nozzles. Please do not change the size of the nozzles. We upgraded to the Revo to improve ease of maintenance and reliability of the printers, but do not currently have a system to support nozzle size changes.
Rebooting Procedure
In order to fully reboot the printer and the Octoprint server attached to it, power off the Pi at the back-upper-left of the printer by toggling it's inline power switch, and turn the printer off using the power switch on the power supply unit at the back of the printer. Then toggle the power supply unit switch back on, and then turn the Pi back on. The Octoprint page should be reachable in under one minute.
