Prusa MK3S+
Emergency Stop
If you see or hear something going terribly wrong with the printer, you can immediately stop it by pressing the X
button below the dial control. This is equivalent to unplugging the printer and plugging it back in. Examples of situations where you would want to do this: the nozzle is contacting the steel plate, the printer is trying to move the head beyond its rails.
If you just need to stop a print, please press the dial control and select Stop Print
. The X
button sometimes causes the printer to lose some of its settings and need to be recalibrated, so avoid using it for things you can stop normally. But if you are in doubt, do use the X
button.
Control Panel
Octoprint
Stopping or Pausing a print
Firmware Upgrade Warning
Filament
Print Bed Sheet
Nozzles / Hotend
- User Manual
- PrusaSlicer
- STLFinder
- Thingiverse
- Printables
- Yeggi
- Buy from makers on Etsy
Places to buy filament:
- Polymaker
- Amazon
Calibration > First Layer Calibration
process on the control panel (Section 6.3.9 of the handbook). You can also adjust it live while your first layer prints (Press the control wheel while printing, selectLive adjust Z
). If you find that you need to set a Z value beyond -2.000mm, please file a problem report. You can continue your print, but this indicates that the Z sensor needs to be adjusted. - Contact a steward
- Use
Settings > Move axis > Move Z
to raise the nozzle so you can see under it - Touch some cool plastic to the still-hot plastic on the nozzle. It should stick and let you pull the mess away
Other
Octoprint
Moving the printers
Rebooting Procedure
Z Problems
- Run through the
process on the control panel (Section 6.3.9 of the handbook) - If you have trouble calibrating Z in that, these models have been useful:
- If you have to set the Z further out than -2.000mm, the Z sensor probably needs to be adjusted. See 6.3.10.2 of the handbook
- The proper height for the sensor is about a zip tie's thickness
- If you move the Z sensor, do a Z Calibration, then calibrate the first layer again
