Prusa MK3S+
Revision as of 18:27, 17 October 2024 by Aneel (talk | contribs) (→‎Z Problems)
Apollo
Status Active
Manufacturer Prusa
Model i3 MK3S+ & Pi 3B
Nozzle Size 0.4mm
Nozzle Count 1
Filament Size 1.75mm
Max Bed Temperature 122C
Max Nozzle Temperature 295C
Max Print Speed 100mm/s
Extruder Type Direct
Manual MK3S+ Handbook
Hermes
Status Active
Manufacturer Prusa
Model i3 MK3S+ & Pi 4B
Nozzle Size 0.4mm
Nozzle Count 1
Sunwukong
Status Active
Manufacturer Prusa
Nozzle Size 0.4mm
Nozzle Count 1
Apollo, Hermes, and Sunwukong
All three printers
Emergency Stop
Control Panel
Octoprint
Stopping or Pausing a print
Firmware Upgrade Warning
Filament
Print Bed Sheet
Calibrated for Smooth1
Nozzles / Hotend
yo.asmbly.org
Places to buy filament:
  5. Contact a steward
Other
Octoprint
Moving the printers
Rebooting Procedure
Z Problems
  2. Run through the Calibration > First Layer Calibration process on the control panel (Section 6.3.9 of the handbook)
    1. Calibration Network
    2. Calibration E
    1. The proper height for the sensor is about a zip tie's thickness
