Grizzly G0817 Bandsaws
(Redirected from 000185)
Asmbly has two Grizzly G0817 14" bandsaws for contour cutting.
The brake pedal is the off switch. Push hard.
No adjustments allowed, except for Fence & Cutting height.
These saws lack automatic dust collection. Vacuum around the saw and inside the cabinet after use.
These saws take 120" blades. We typically equip one with a 1/8" blade for fine contours and one with a 3/8" general-purpose blade.
  • No blade changes - call a steward or report via red QR code.
  • Do not adjust bearings or tension. Do not release tension.
  • If you see a problem that you think needs these adjustments, report using any red QR code.
Maximum cutting height is 14", maximum cutting width is 13½"
