Tarkin
Tarkin is the new large-format laser cutter in the space, currently the most capable of our lasers for 2-d operations. It's a hot-rod custom-built laser cutter based on an RF CO2 10.6um laser and the latest in C-rail linear rails and a closed-loop servo-stepper motion system with a Ruida RDC6445G controller running Lightburn software. It features 225W of power on a 1.6M x 1.0 M (63"x39") cutting bed, powered Z, 16MP alignment camera, and air assist.
Setup
1. Locate Fire Extinguisher
2. Main Power Switch
3. Chiller switch
4. Locate E-STOP button
Important Terms
Machine bed
Material
Lightburn
Workspace
Lightburn's work area on the PC. This is the same as the machine bed only if you make the workspace size the same as machine bed size and operate in absolute coordinates. Otherwise, where your job is placed on the workspace is not necessarily where the job will be when you go to the machine bed, and your workspace can be declared in a different size than the machine bed. Note that in either case, your job (the actual content) will probably be smaller than the whole declared workspace, and cannot be located outside the workspace when you actually want to send it to the laser. Raster content cannot use the entire width of the workspace as it requires enough extend space on either side to decelerate and accelerate back. You will not know if it has enough extend space until trying to run the job at the machine.
Job
User origin
Vector Cutting
Vector Engraving
Rastering
Fill
Focusing
Origins
Absolute coords
User origin
Camera-placed absolute coords
Rastering
MAX RASTER
Types of Rastering:
FILL
GRAYSCALE 2D
DITHER/HALFTONING 2D
Rastering with Focus+
Don't put your work up against the left or right side of the honeycomb as an alignment ruler. That will likely trip this error.
Extend space creates a slightly complicated relationship with raster speed and ultimate job time. 300mm/sec is very little extend space, 1-1000mm/sec requires 75mm on either side. For example, with a raster image only 25mm wide, running 1000mm/sec will actually take longer than 300mm/sec as it must use a wide margin of extend space to brake and reverse up to that high speed that is only used for 25mm. However, for a 1 meter wide raster, 1000mm would be substantially faster. The time wasted braking and reversing through the extend space on each pass is a fixed time per line, but the bulk of the time per line is spent on the 1 meter raster job which goes twice as fast.]
1000mm/sec is best for wide rasters (>400mm as a wild guess)
The FRAME button does NOT show the bounds of Extend Space. Take care when placing holddown weights (which, unlike the magnetic clamps, require more clearance than available so the head will strike it) to the left or right of a raster. There is no easy way to guess how much Extend Space will be used. The amount of Extend Space also depends on the machine parameters, which may be tweaked from time to time. In general these future improvements should reduce, not increase, the amount of Extend Space needed
Shutdown
Turn off main power
Turn off chiller
Order is NOT important
Usable
Plywood quality and "Patches"
Russian Baltic Birch is the best type of plywood for lasering. ALL plies are birch and it is significantly stronger than other plywoods of similar thickness, including domestic or Indonesian "birch plywood". The plies of RBB are always the same thickness and there are no major "patches". RBB not sold in hardware stores but available at Austin Fine Lumber and Plywood, about a mile from Asmbly. It comes in 5'x5' (1525mm x1525mm) sheets in 3mm, 6mm, 9mm, 12mm, and 15mm. Woodcraft sells cut pieces of RBB at a somewhat higher price per sq meter. Ask for interior grade plywood - it has a different amount or composition of glue than exterior grade and produces significantly better results.
Prohibited
NO PVC
NO PTFE (Teflon)
Produces toxic and corrosive gases
NO Polycarbonate
NO METAL
NO FOOD
Copper Wire Flame Test
When in doubt, there is a copper wire "flame test" specifically for the presence of toxic/corrosive chlorine as found in PVC:
Machine Errors
Causes:
WATER PROT
SYS ALARM, MACHINE PROTECTED
Likely causes:
FRAME SLOP
Current Quirks
Table shifting when moving Z
Fixed air assist
Expected resolution
Drive Faulting
Cone clipping
