Powermatic 2820EVS Drill Press
Revision as of 22:29, 14 December 2025 by Aneel (talk | contribs)
Asmbly has recently acquired a Powermatic 2820EVS variable-speed drill press for the woodshop. This machine is for use with wood only - no metal, no coolant, and definitely no cutting oil!
  • 1hp motor
  • 20" swing
  • 6" spindle travel
  • 5/8" keyed chuck
  • low range 150-870rpm
  • high range 600-3600rpm
  • Change Speed Range Only With Machine Off!
