Sawstop ICS Table Saw
Revision as of 03:29, 11 January 2023 by Cfstaley (talk | contribs) (Updated with Neon Store link, removed how to purchase blades and cartridges from Amazon.)
The SawStop 10" Industrial Cabinet Saw model ICS73230 is a 230v, 60hz, 17.8amp, 3ph, 7.5hp wonder with plenty of extended table space.
A general-purpose blade suitable for most applications is provided by Asmbly. We understand that some users may wish to provide a more application-specific blade; if this is the case, please discuss with the Workshop Committee on getting checked out to change the blade and properly adjust the SawStop brake cartridge. Inexpert blade changes can lead to misfire of the blade brake.
If you cause the brake to fire, you will be charge for a replacement! Go to the Neon store and purchase a blade and cartridge for $160.
https://asmbly.app.neoncrm.com/np/clients/asmbly/giftstore.jsp?orgId=asmbly
  • Metallic fixtures (like an aluminum miter gauge)
  • Very wet wood, especially when its treated
  • Metallized plastics (like mirrored acrylic)
  • Heavily carbonized (ie burnt) wood
  • Embedded fasteners (screws / nails / staples)
