Powermatic WB-37 Wide Belt Sander
Revision as of 15:58, 27 November 2022 by Jon (talk | contribs) (Jon moved page Powermatic WB37 Wide Belt Sander to Powermatic WB-37 Wide Belt Sander without leaving a redirect)
The Powermatic WB-37 is used for finishing and light flattening of stock up to 37" wide and 6" thick. It boasts an oscillating 37"x75" sanding belt powered by a 20HP motor. Stock feed speed is variable.
This tool is owned by Jeff McAdams and hosted at Asmbly for members to use. Please submit a problem report if maintenance is required.
