Sawstop ICS Table Saw
Revision as of 15:03, 4 April 2023 by Jon (talk | contribs)
  • model ICS51230 5hp is owned by Asmbly
  • model ICS73230 7.5hp is hosted by Danny
If you cause the brake to fire, you will be charge for a replacement! Go to the Neon store and purchase a blade and cartridge for $160.
  • Metallic fixtures (like an aluminum miter gauge)
  • Very wet wood, especially when its treated
  • Metallized plastics (like mirrored acrylic)
  • Heavily carbonized (ie burnt) wood
  • Embedded fasteners (screws / nails / staples)
