Sawstop ICS Table Saw
- model ICS51230 5hp is owned by Asmbly
- model ICS73230 7.5hp is hosted by Danny
If you cause the brake to fire, you will be charge for a replacement! Go to the Neon store and purchase a blade and cartridge for $160.
