Tormach PCNC 1100
Asmbly owns a Tormach PCNC 1100 Series 3 CNC mill.
- 1.5hp R8 Spindle
- Table Size: 34" x 9.5"
- Table Slots: 3 Slots 5/8"
Purchased by the ATX Hackerspace in January of 2019.
Serial number 4848
Accessories
The mill now has the following accessories:
- How to use the fixture plate:
- Treat the fixture plate as a precision instrument. It is precision ground out of 6061 Aluminum, and won't function correctly for long term use if it excessively nicked or scratched.
- Electronic Probe
- To start, ALWAYS plug the USB-C cable into the probe first, and then the DIN5 cable into the accessory port on the machine electronics cabinet. The probe will light up green when the connection is good. DO NOT proceed if the light is not on. The machine will happily crash and ruin the probe if you run a probing routine without power to the probe.
