Tormach PCNC 1100
Asmbly owns a Tormach PCNC 1100 Series 3 CNC mill.
  • 1.5hp R8 Spindle
  • Table Size: 34" x 9.5"
  • Table Slots: 3 Slots 5/8"
Purchased by the ATX Hackerspace in January of 2019. Serial number 4848
Accessories
The mill now has the following accessories:
    • How to use the fixture plate:
      • Treat the fixture plate as a precision instrument. It is precision ground out of 6061 Aluminum, and won't function correctly for long term use if it excessively nicked or scratched.
  • Electronic Probe
