Storage Policies
Revision as of 23:41, 20 February 2024 by Snestle (talk | contribs)
Storage at Asmbly
In an effort to keep Asmbly clean and organized, we have rules about how materials and projects can be stored here.  You are required to take your projects with you when you leave for the day, however if circumstances prevent you from doing so there are options available.  Anything left at the space is at your own risk and is likely to be discarded if it violates our storage policy as outlined below.  Each member is responsible for maintaining a safe, neat, and professional workspace.
Storage Policy Overview
  • Any items stored in the workshop must be in an approved storage area and require a storage ticket. Ticket rack is hanging on the shelving in front of the storage area. Fill the form out completely with name, date, and phone number.
  • Your items must be safely and neatly arranged.
  • There is no storage under the workbenches without documented special permission.
  • Failing to properly label stored items or exceeding the maximum storage time without documented approval will result in items being placed in scrap cart or disposed of.
Storage Area Location Material Type Max Time
A orange metal shelf under loft sheet goods 7 days
B space to the right of shop bathroom vertical storage 7 days
C two shelves under paid storage loft projects 7 days
D two worktables nearest CNC router glue up and finishing large projects 24 hours
Special Exemption Other areas TBD by Asmbly Asmbly approved exemptions only Asmbly approval only
Long-term Storage
If you have a project that is too big to take home with you every day, and will take more than 1 week to complete, you may request special exemption storage in another area by submitting an application BEFORE leaving items in the space.
Other storage areas are a very limited option that is available on a case to case basis depending on storage availability and storage size needs.  Requests for special exemption storage must include an estimate of space needed and length of time for project to be completed.  Note that long-term storage is only approved for 30 days at a time.  If you need more than 30 days, you will need to reapply.  You will also be asked to provide regular reports of project progress to the board as you work on it.
Address your request, along with project information and space requirments to Leadership@asmbly.org. You will be informed on where it is best to store it at that time.
If you require routinely storing tools or materials at Asmbly, we have limited paid storage options available. Currently, we have 2'x2' spaces available for rent on a monthly basis for $25/space/month in the loft above storage areas A and C. Email membership@asmbly.org if you are interested in acquiring a space.
