Blue
Revision as of 22:09, 8 May 2024 by DanHawn (talk | contribs) (→‎Usage: moved this section to the main Lasers page)
Asmbly owns a Universal Laser Systems PLS 6.60 laser cutter colloquially known as "Blue". It is a 60W CO2 laser with 32" x 18" bed capable of cutting, engraving, and marking a number of different materials quickly and accurately when driven from CAD software such as CorelDraw and Inkscape.
ClassWarningIcon.png Members must complete the Small Lasers Class before using this tool
ULS 6.60 Laser Cutter
Laser Cutter Settings
Manuals
Theory: How it Works
  • Don't use the laser when the mirror and/or lens are dirty - especially not at high power settings - because doing so causes the dirt to get very hot and that can permanently ruin the gold coating or even crack the optics - which cost hundreds of dollars to replace and could result in the laser cutter being offline for weeks.
  • Don't touch or attempt to clean the lens/mirror unless you've been properly trained to do so. The procedure for cleaning these delicate parts is described in Cleaning the Laser Cutter, but this is a task that should not be undertaken without specific training because these parts are fragile (they're made of a surprisingly soft material) and it's easy to damage the thin gold coating by cleaning them even slightly incorrectly.
  1. Enter your suspicions into the log book.
  2. eMail the issue to the mailing list.
  3. Do not operate the laser cutter or you could end up with...
By convention:
  • Draw raster objects as image files in shades of grey (darker means more laser power, lighter means less)
  • Lines to be cut all the way through should be drawn in red.
  • Lines to be etched in either blue or green.
External Links
Maintenance and Parts
