Lightburn
Revision as of 15:35, 24 June 2024 by DanHawn (talk | contribs)
Helpful Youtube Links on Lightburn
LightBurn Tips I Wish I Knew Earlier
A Lightburn Material Database for Tarkin's material settings ready to install on your machine is located here [TBD: add '$wgFileExtensions = array( "clb", lbset" );' to LocalSettings.php]
