Elegoo Saturn 3 Ultra
Revision as of 21:20, 4 September 2024 by YellowEng (talk | contribs) (→‎Equipment-Specific Safety: Now bullet-pointed)
Unnamed SLA Printer
Manufacturer Elegoo
Model Elegoo Saturn 3 Ultra
LCD 10-inch 12K Mono LCD
System EL3D-4.0
Layer Thickness 0.01 - 0.2mm
Z Axis Accuracy 0.01mm
Weight 16.2kg
  • If the printing fails, you need to clean the excess cured resin in the resin tank and change the resin, otherwise, it may cause damage to your printer.
The pricing of ABS like resin and Standar resin is $0.10 per gram.
You may purchase resin here.
Chitu Box Slicer Setup
  2. Select ELEGOO Saturn 3 Ultra as the default printer.
Default Parameters in Chitu Box
Resin Density: 1.1g/mL
Layer Height: 0.05mm
Number of Bottom Layers: 2
Exposure Time: 2.5s
Leveling the bed
Leveling the bed
Tool Use
SIG Information (if relevant)
Common Projects
