Elegoo Mars 2 Pro
Revision as of 01:06, 6 September 2024 by YellowEng (talk | contribs) (Included steps for leveling the bed.)
Asmbly owns the ELEGOO Mars 2P, a cure post-processing equipment.
Photo of the Elegoo Mars 2 Pro
Unnamed Cure Post-Processor
Manufacturer Elegoo
Model Elegoo Mars 2 Pro
Technology UV Photocuring
Layer Thickness 0.01 - 0.2mm
Printing Speed 30 - 50mm/h
Z Axis Accuracy 0.00125mm
XY Resolution 0.05mm (1620 * 2560)
Build Volume 129mm(L) * 80mm(W) * 160mm(H)
Light Source UV Integrated Light (Wavelength 405 nm)
Weight 6.2kg
Operation 3.5-inch Capacitive Touch Screen
Power Requirements 100-240V 50/60Hz
Printer Dimensions 20cm(L) * 20cm(W) * 41cm(H)
Etiquette (if relevant)
Example:
Leveling the Bed
  1. Press "Tool" and the "Manual" on the touchscreen to enter the leveling interface.
  2. Place an A4 sheet of paper on the LCD screen, ensuring both the screen and the build plate are clean.
  3. Loosen the screws securing the build plate.
  4. Tap the home icon to start the Z=0 process.
  5. Once Z=0 is set, align the plate to avoid it touching the vat incorrectly.
  6. Tighten the two screws to level the plate. There should be some resistance when pulling the paper. If there is no resistance, readjust the screws to level the plate. If there is too much resistance, lift the plate and reset Z=0 for this position.
Tool Use
  • What to clean
  • How to clean
  • Where to dispose of waste
Example for Miter Saw:
  1. Brush off top surface
  2. Brush around machine
  4. Sweep floor
ELEGOO Mars 2 Pro
SIG Information (if relevant)
Common Projects
