Elegoo Mars 2 Pro
Asmbly owns the ELEGOO Mars 2P, a cure post-processing equipment.
Manufacturer | Elegoo |
Model | Elegoo Mars 2 Pro |
Technology | UV Photocuring |
Layer Thickness | 0.01 - 0.2mm |
Printing Speed | 30 - 50mm/h |
Z Axis Accuracy | 0.00125mm |
XY Resolution | 0.05mm (1620 * 2560) |
Build Volume | 129mm(L) * 80mm(W) * 160mm(H) |
Light Source | UV Integrated Light (Wavelength 405 nm) |
Languages | Chinese, English, Japanese, Dutch, Korean, French, German, Russian, Italian, Spanish, Turkish, Portuguese |
Connectivity | USB Interface & Wi-Fi |
Weight | 6.2kg |
Operation | 3.5-inch Capacitive Touch Screen |
Power Requirements | 100-240V 50/60Hz |
Printer Dimensions | 20cm(L) * 20cm(W) * 41cm(H) |
Etiquette (if relevant)
Example:
Resin Safety
- Avoid breathing vapors.
The pricing of ABS like resin and Standar resin is $0.10 per gram.
You may purchase resin here.
Available Resin Materials
Leveling the Bed
Tool Use
- What to clean
- How to clean
- Where to dispose of waste
Example for Miter Saw:
- Brush off top surface
- Brush around machine
- Sweep floor
- Wall vacuum hose works well
SIG Information (if relevant)
