Elegoo Mars 2 Pro
Asmbly owns the ELEGOO Mars 2P SLA printer.
| Manufacturer | Elegoo |
| Model | Elegoo Mars 2 Pro |
| Technology | UV Photocuring |
| Printing Speed | 30 - 50mm/h |
| Z Axis Accuracy | 0.00125mm |
| XY Resolution | 0.05mm (1620 * 2560) |
| Build Volume | 129mm(L) * 80mm(W) * 160mm(H) |
| Light Source | UV Integrated Light (Wavelength 405 nm) |
| Connectivity | USB Interface |
| Weight | 6.2kg |
| Operation | 3.5-inch Capacitive Touch Screen |
| Power Requirements | 100-240V 50/60Hz |
| Printer Dimensions | 20cm(L) * 20cm(W) * 41cm(H) |
- Keep the Mars 2 Pro 3D Printer and its accessories out of the reach of children.
Resin Safety
- Avoid breathing vapors.
You may purchase resin here.
Available Resin Materials
Chitu Box Slicer Setup
- Go to "Settings" and Select ELEGOO MARS 2 PRO as the default printer.
Resin Density: 1.1g/mL
Layer Height: 0.05mm
Bottom Layer Count: 3-6 layers
Exposure Time: 1.5-3s (Set according to the layer height and complexity of the model. Thicker layers require longer exposure times, resulting in lengthier prints).
Bottom Exposure Time: 20-40s (Longer exposure times create a stickier bottom on the build plate).
Light-off Delay/Bottom Light-off Delay: 7s/8s
Bottom Lift Distance: 5mm
Lifting Distance: 3-5mm
Bottom Lift Speed: 90mm/min
Lifting Speed: 100mm/min
Retract Speed: 150mm/min
Leveling the Bed
