PolyPrinter 229 Overhaul
Revision as of 03:15, 6 September 2024 by YellowEng (talk | contribs)
Unknown Name (Polyprinter 229)
Status Active
Manufacturer Polyprinter
Model 229
Nozzle Size 0.4mm
Nozzle Type Brass(?)
Nozzle Count 1
Filament Size 1.75mm
Print Volume 229 x 229 x 229mm
Max Bed Temperature 125(?)C
Max Nozzle Temperature 300(?)C
Max Print Speed 250(?)mm/s
Extruder Type Direct
Manual Unknown
Control Interface Unknown
Network Address Unknown
Etiquette (if relevant)
Example:
Tool Use
  • What to clean
  • How to clean
  • Where to dispose of waste
Example for Miter Saw:
  1. Brush off top surface
  2. Brush around machine
  4. Sweep floor
SIG Information (if relevant)
Common Projects
Critical Info!
  • Do NOT use metal tools on the Bed
  • Avoid touching the plate with your fingers. Skin oil can affect performances.
  • Requires use of KISSlicer
  • Only use Polyprinter brand filament reels
