PolyPrinter 229 Overhaul
| Status | Active |
| Video Feed | Unknown |
| Manufacturer | Polyprinter |
| Model | 229 |
| Nozzle Size | 0.4mm |
| Nozzle Type | Brass(?) |
| Nozzle Count | 1 |
| Filament Size | 1.75mm |
| Print Volume | 229 x 229 x 229mm |
| Max Bed Temperature | 125(?)C |
| Max Nozzle Temperature | 300(?)C |
| Max Print Speed | 250(?)mm/s |
| Extruder Type | Direct |
| Manual | Unknown |
| Network Address | Unknown |
Members are encouraged to bring their own filament for 3D printing projects. However, for your convenience, a limited supply of free filament is available for use with the Makerspace 3D printers. This filament can be found on the table next to the printers, as well as in the storage area beneath them. Please note that the free filament is intended for community use, so availability may vary.
Material Properties, Configuration, and Vendors
To be added as a separate wiki page.
Tool Use
- What to clean
- How to clean
- Where to dispose of waste
SIG Information (if relevant)
Common Projects
Critical Info!
- Requires use of KISSlicer
