Elegoo Saturn 3 Ultra
Manufacturer | Elegoo |
Model | Elegoo Saturn 3 Ultra |
LCD | 10-inch 12K Mono LCD |
System | EL3D-4.0 |
Slicer Software | CHITUBOX & Voxeldance Tango |
Technology | MSLA Stereolithography |
Layer Thickness | 0.01 - 0.2mm |
Printing Speed | Maximum 150mm/h |
Z Axis Accuracy | 0.01mm |
XY Resolution | 19 x 24μm (11520 x 5120) |
Build Volume | 218.88mm(L) * 122.88mm(W) * 260mm(H) |
Light Source | COB + Refractive Light Source (Wavelength 405 nm) |
Languages | Chinese, English, Japanese, Dutch, Korean, French, German, Russian, Italian, Spanish, Turkish, Portuguese |
Connectivity | USB Interface & Wi-Fi |
Weight | 16.2kg |
Operation | 4.0-inch Capacitive Touch Screen |
Power Requirements | 100-240V 50/60Hz 24V 7.5A |
Printer Dimensions | 305.9mm(L) * 273mm(W) * 562.5mm(H)
- Keep the 3D printer and its accessories out of reach of children.
Resin Safety
- Avoid breathing vapors.
You may purchase resin here.
Available Resin Materials
Chitu Box Slicer Setup
- Go to "Settings" and select ELEGOO Saturn 3 Ultra as the default printer.
Resin Density: 1.1g/mL
Layer Height: 0.05mm
Number of Bottom Layers: 2
Exposure Time: 2.5s
Leveling the bed
