Elegoo Mars 2 Pro
Revision as of 21:45, 6 September 2024 by YellowEng (talk | contribs) (Included Post-processing reminder by the cleaning section)
Asmbly owns the ELEGOO Mars 2P SLA printer.
Photo of the Elegoo Mars 2 Pro
Unnamed Cure Post-Processor
Manufacturer Elegoo
Model Elegoo Mars 2 Pro
Technology UV Photocuring
Layer Thickness 0.01 - 0.2mm
Printing Speed 30 - 50mm/h
Z Axis Accuracy 0.00125mm
XY Resolution 0.05mm (1620 * 2560)
Build Volume 129mm(L) * 80mm(W) * 160mm(H)
Light Source UV Integrated Light (Wavelength 405 nm)
Connectivity USB Interface
Weight 6.2kg
Operation 3.5-inch Capacitive Touch Screen
Power Requirements 100-240V 50/60Hz
Printer Dimensions 20cm(L) * 20cm(W) * 41cm(H)
  • Keep the Mars 2 Pro 3D Printer and its accessories out of the reach of children.
Resin Safety
  • Avoid breathing vapors.
The Mars 2 Pro is an SLA printer known for its high-resolution output and consistent print quality. It supports file uploads via USB, and its impressive resolution makes it ideal for detailed and precision projects.
You may purchase resin here.
Available Resin Materials
Chitu Box Slicer Setup
  2. Go to "Settings" and select ELEGOO MARS 2 PRO as the default printer.
Resin Density: 1.1g/mL
Layer Height: 0.05mm
Bottom Layer Count: 3-6 layers
Exposure Time: 1.5-3s (Set according to the layer height and complexity of the model. Thicker layers require longer exposure times, resulting in lengthier prints).
Bottom Exposure Time: 20-40s (Longer exposure times create a stickier bottom on the build plate).
Light-off Delay/Bottom Light-off Delay: 7s/8s
Bottom Lift Distance: 5mm
Lifting Distance: 3-5mm
Bottom Lift Speed: 90mm/min
Lifting Speed: 100mm/min
Retract Speed: 150mm/min
Leveling the Bed
  1. Press "Tool" and the "Manual" on the touchscreen to enter the leveling interface.
  2. Place an A4 sheet of paper on the LCD screen, ensuring both the screen and the build plate are clean.
  3. Loosen the screws securing the build plate.
  4. Tap the home icon to start the Z=0 process.
  5. Once Z=0 is set, align the plate to avoid it touching the vat incorrectly.
  6. Tighten the two screws to level the plate. There should be some resistance when pulling the paper. If there is no resistance, readjust the screws to level the plate. If there is too much resistance, lift the plate and reset Z=0 for this position.
Post-Processing
ELEGOO Mars 2 Pro
3D Printers Space Team
Common Projects
