Jet 22-44 Plus Drum Sander
| Grit | Jet Part Number | Buy Online |
| 36 | 60-2036 | Buy on Amazon |
| 60 | 60-2060 | Buy on Amazon |
| 80 | 60-2080 | Buy on Amazon |
| 100 | 60-2100 | Buy on Amazon |
| 120 | 60-2120 | Buy on Amazon |
| 180 | 60-2180 | Buy on Amazon |
| 220 | 60-2220 | Buy on Amazon |
This tool is owned by Joe Ngo and hosted at Asmbly for members to use. Please submit a problem report if maintenance is required.
