Soldering Overhaul
Revision as of 01:15, 2 October 2024 by YellowEng (talk | contribs) (→‎Setup: Drafted a setup section for the soldering iron.)
The Electronics lab has an assortment of soldering and de-soldering equipment.
  • 1.5hp R8 Spindle
  • Table Size: 34" x 9.5"
  • Table Slots: 3 Slots 5/8"
Safety glasses must be worn when working with the soldering station, as solder can "spit." Never touch the tip of the soldering iron to avoid burns, and always work with the soldering iron above the workbench. When not in use, the soldering iron must be returned to its stand and never laid on its side. The fume extractor should be powered on while soldering to mitigate health risks from inhaling fumes, and skin contact with melted solder should be avoided.
The soldering iron should only be used for fusing solder, not for other purposes such as burning through materials. Avoid using the soldering iron on the plastic insulation of wires; instead, use a wire stripper to remove the insulation. Additionally, avoid prolonged contact between the soldering iron and PCB boards, as the iron should primarily make contact with the solder.
Prongs or tweezers are recommended for holding wires while soldering, minimizing the risk of accidental contact with the soldering iron and reducing the chance of burns from conductive heat in the wire. Finally, when finished using the soldering iron, always clean the tip before returning it to its station.
Soldering uses a fusible metal alloy (solder) to join two metal surfaces by heating them and applying melted solder. It creates electrical connections on PCBs, allowing current to flow between the soldered components.
The soldering station can accommodate two common types of solder wire.
Tin-Lead Rosin Core Solder Wire
Typically has a low melting point, with excellent flow, wetting, and electrical conductivity. Contains lead, which poses health risks through the release of toxic fumes.
Lead-Free Rosin Core Solder Wire
Typically has a higher melting point, with good flow, wetting, and electrical conductivity. Produces less harmful fumes, making it safer to work with.
Setup
Preparing the Soldering Iron
  • Turn the the power supply unit for the soldering iron.
    • Adjust the temperature of the soldering iron as needed. 400°C typically works for most applications.
  • Wait for about 2 minutes for the soldering iron to heat up.
  • Pick up the soldering iron, burn some solder on the tip of the iron, and clean the tip with copper wool.
    • Doing this before soldering helps improve heat transfer, prevent oxidation, and enhance soldering quality.
Soldering
  • Use clamps to hold your board in place.
  • Place the solder wire on the surface you wish to fuse with your wire, then position the soldering iron on top of the solder wire without letting the iron touching the surface. Hold it in place until the solder melts.
    • A good solder joint should have a smooth, shiny appearance, indicating proper melting and wetting of the solder. It should also be evenly distributed around the connection and have no cracks or excessive lumps.
  • Move the solder wire away, and hold your conductive wire on the melted solder.
    • If the wire is insulated, use wire strippers to remove the insulation.
  • Move the soldering iron away from the solder, allowing it to harden so that the wire remains adhered to the surface.
  • Use the copper wool to clean the soldering iron after every solder.
Cleaning Up Solder
To clean up solder on a wire or surface, heat the solder with the soldering iron, then place a solder wick near the iron and solder to absorb the solder. You can also use a solder sucker to vacuum the melted solder.
Turning Off the Soldering Iron
When finished using the soldering iron, always ensure to clean the iron tip before storing it back to its holder. Turn off the heat when it is not used.
Tooling
Electronics Shop Space Team
SIG Information
Speeds and Feeds Resources
Common Projects
