Blue
Asmbly owns a Universal Laser Systems PLS 6.60 laser cutter colloquially known as "Blue". It is a 60W CO2 laser with 32" x 18" bed capable of cutting, engraving, and marking a number of different materials quickly and accurately when driven from CAD software such as CorelDraw and Inkscape.
Members must complete the Small Lasers Class before using this tool
ULS 6.60 Laser Cutter
Blue's bed size is [CITATION NEEDED] - this is important for when you're sending artwork to the laser.
Laser Cutter Settings
Currently the focus tool for Blue is a 3D printed part that says Pearl on it, but works for both machines. (as of Nov 9 2024)
To focus the laser, just align the focus tool to the screw on the laser head and adjust the Z-height to meet your material.
Manuals
- PLS Installation Manual
- PLS User Guide
- Print Driver-Advanced Manual Control
- UCP-Universal Control Panel
- PLS Service Manual
Theory: How it Works
- Don't use the laser when the mirror and/or lens are dirty - especially not at high power settings - because doing so causes the dirt to get very hot and that can permanently ruin the gold coating or even crack the optics - which cost hundreds of dollars to replace and could result in the laser cutter being offline for weeks.
- Don't touch or attempt to clean the lens/mirror unless you've been properly trained to do so. The procedure for cleaning these delicate parts is described in Cleaning the Laser Cutter, but this is a task that should not be undertaken without specific training because these parts are fragile (they're made of a surprisingly soft material) and it's easy to damage the thin gold coating by cleaning them even slightly incorrectly.
- Enter your suspicions into the log book.
- eMail the issue to the mailing list.
- Do not operate the laser cutter or you could end up with...
By convention:
- Draw raster objects as image files in shades of grey (darker means more laser power, lighter means less)
- Lines to be cut all the way through should be drawn in red.
- Lines to be etched in either blue or green.
External Links
- Regal Plastics - Local supplier
- Tissues for cleaning optics
- ULS 3D calibration
- Why not to leave the laser
- Typeface for stencils
- Laser Origami
- Laser cut round stools
- Removing wood residue
- Tabbed box maker
- Boxes.py
- TherMark laser bonded marking
- USL Materials Library
- Tuck box python script
- Lasersaur DIY laser cutter
- How to make snug joints in acrylic
Maintenance and Parts
