Ceramics Policy
Revision as of 21:58, 21 March 2025 by Valerie (talk | contribs) (Protected "Ceramics Policy": Organization policies ([Edit=Allow only administrators] (indefinite) [Move=Allow only administrators] (indefinite)))
Introduction
Ceramics Safety & Information (CSI) is the required free class you must take before access to the studio with membership is granted.  We are all caretakers of the shared space, so the cleanliness and maintenance is up to you!
Usage Areas
Tools
  • Pottery Wheels: 5 machines available: Max booking is 5 hours of time
  • Extruder:  1 tool available: Comes with the extruder table next to it, max booking is 3 hours of time
    • If it is not booked you can rebook the Extruder in Skedda up to 3 more hours
  • Slab Roller: 1 tool available: Max booking is 3 hours of time
    • If it is not booked you can rebook the Slab Roller in Skedda up to 3 more hours
    • NOTE: If you are making a lot of slabs, it is recommended you Book a Table with the note, “Using Slab Roller” as a User in the studio to give you somewhere besides your shelf  to put the slabs.
Studio User
You must book yourself as a User if you plan on sitting at a Handbuilding Table, regardless of tool booking. You must also reserve time for each tool you plan to use on Skedda (see above). It is your responsibility to CHECK SKEDDA to make sure the tool is not booked. Allow for clean up time within your booked time, NOT after. Members booked in Ceramics at the same time should work together to clean and coordinate space use.
  • Handbuilding Tables: 8 Users can Book up to 5 hours of time between 2 tables (4 Users/table)
  • Glaze Area: 2 Users can Book up to 5 hours at a time in the Glaze area
    • NOTE: If you are glazing a large amount of items, please book a User table space in addition to the glaze area and put a note on the Table booking you will be, “Using Table for Glazing”, and on the Glaze booking that you will be, “Using a table”
    • If it is not booked you can rebook the Table  in Skedda up to 5 more hours
Community Tools/Areas
  • We have a Blue Ox Air filtration system to be installed soon to help cut back on particulates in the air
Studio Shelves
Kilns/Kiln Room
Kiln Shelves
Members are responsible for moving their OWN pieces to the Greenware and Glaze Shelves when ready.
    • STUDENTS: we have Open hours with a Steward on Duty they can come by to retrieve their piece
      • Mondays: 4-8
      • Wednesdays: 4-8
      • Saturdays: 12-4
      • Mondays: 4-8
      • Wednesdays: 4-8
      • Saturdays: 12-4
Clay & Glazes
Clays Provided in Studio
  1. Cinco Blanco: https://www.armadilloclay.com/store/p11/Cinco_Blanco.html#/
  2. Buffalo Wallow: https://www.armadilloclay.com/store/p12/Buffalo_Wallow.html#/
  • Purchase Clay at the Square ReaderKiosk in studio or [./Https://checkout.square.site/buy/2QBIDIDW5NY4BUHSYKAVY4OG Online Square Store]
  • Place provided receipt sticker on your bag/box of purchased clay and write your name on the sticker
Armadillo Clay is a locally owned and operated store that has over 40 years of experience in Clay and its related tools. They are super nice and helpful and we are excited to be collaborating with them!
NOTE: Clay brought in must be labelled with the sticker and sharpie found at the Clay Station at Asmbly BEFORE being stored on your shelf!!
Glazes Provided in Studio
All glazes provided are lead free and Food Safe.
Lay down brown paper provided to avoid getting glaze on the clay tables or drying boards.
Clean up glaze brushes and bowls provide for community use when finished.
These Mid-fire Glazes are currently available in studio for Members & Classes to use:
  1. Snow: https://www.armadilloclay.com/store/p620/Snow_%28C-10%29.html#/
  2. Obsidian: https://www.armadilloclay.com/store/p617/Obsidian_%28C-1%29.html#/
  3. Marigold: https://www.armadilloclay.com/store/p643/Marigold_%28C-60%29.html#/
  4. Sky: https://www.armadilloclay.com/store/p624/Sky_%28C-21%29.html#/
  5. Cobalt: https://www.armadilloclay.com/store/p623/Cobalt_%28C-20%29.html#/
  6. Snapdragon: https://www.armadilloclay.com/store/p639/Snapdragon_%28C-54%29.html#/
  1. Amaco Celadons, $21.00: https://www.armadilloclay.com/store/c37/Amaco_Celadons.html#/
  2. Amaco Satin Matte, $21.00: https://www.armadilloclay.com/store/c39/Amaco_Satin_Matte.html#/
NOTE: Glazes brought in must be labelled with the sticker and sharpie found at the Clay Station at Asmbly BEFORE being stored on your shelf!!
Usage Violations
    • It could result in Kiln damage
  • There will be a testing and approval process created in the future for other clay bodies and glazes, but currently there are no exceptions
Discipline/Violations Policy
