Clay - Asmbly Approved
Revision as of 16:38, 4 June 2025 by Julirenner (talk | contribs) (added approved clays and new clays approval process)
1. Approved Clay bodies
Our current fully approved clay bodies are:
  • Buffalo Wallow - supplier Armadillo Clay
  • Cinco Blanco - supplier Armadillo Clay
The fully approved clay bodies can be purchased inside our Ceramics shop at the same price you would purchase them at Armadillo Clay.
We will gradually increase the amount of clays we allow users to fire at ASMBLY, but they all must be mid-fire clay bodies,bisqued at cone 04, because this is the temperature we are currently bisquing in our kilns AND it is the temperature recommended for bisque pieces by most commercial glazes and dips.
To align with that spirit, we have a Clay Body & Glaze Approval System.
2. Our Clay Body & Glaze Approval System:
Non-Approved clay bodies must go through the following steps to be approved:
  1. Bisque Fire:
    1. If you desire to use you own glaze you must follow the glaze approval system (see Approved Glazes and Glaze Approval System).
