Clay - Asmbly Approved
Revision as of 20:40, 12 December 2025 by Julirenner (talk | contribs) (→‎1. Approved Clay bodies)
Our current approved clay bodies are the following mid-fire (cones 5/6)commercial clays that can be purchased at Armadillo Clay:
  • Buffalo Wallow
  • Cinco Blanco
  • Buffalo Wallow with grog
  • Cinco Rojo
  • Cinco Rojo with grog
  • Cone 5 Porcelain
  • Laguna B-Mix cone 5
  • Laguna B-Mix cone 5 with speckles
  • Laguna Speckled Buff
  • Laguna Azabache
  • Laguna B-3 Brown
  • Dark Chocolate no.32 Cone 5/6
Of these approved bodies, two of them can be purchased inside our Ceramics shop:
  • Buffalo Wallow - supplier Armadillo Clay
  • Cinco Blanco - supplier Armadillo Clay
We will gradually increase the amount of clays we allow users to fire at ASMBLY, but they all must be mid-fire clay bodies (cone 5/6), bisqued at cone 04, because this is the temperature we are currently bisquing in our kilns AND it is the temperature recommended for bisque pieces by most commercial glazes and dips.
To align with that spirit, we have a Clay Body & Glaze Approval System.
2. Our Clay Body & Glaze Approval System:
Non-Approved clay bodies must go through the following steps to be approved:
  1. Bisque Fire:
    1. If you desire to use you own glaze you must follow the glaze approval system (see Approved Glazes and Glaze Approval System).
