How to Glaze
Revision as of 00:12, 16 June 2025 by Nona (talk | contribs) (Added a section that reiterates "How to test glazing")
Glaze Approval System
Glazes not already on our approved list must go through a testing process before use on any studio kilns.
Steps for Glaze Testing:
  1. Create a Test Piece: Make a small item no larger than 6" x 6" x 6" (e.g., mug, bowl, sculpture). If you do not have a piece, a vertical test tile made from Cinco Blanco will be provided by Asmbly.
  2. Apply Your Glaze: Glaze your piece or tile using the same technique, layering, color overlaps, and number of coats you intend to use on your final work. Leave at least 1" of unglazed ceramic at the bottom of a piece, or 1/4" to 1/2" if using a test tile.
  3. Label Clearly: Write your name and glaze name on the tile or piece.
  4. Submit to Glaze Test Shelf: Place on the designated Glaze Test shelf near the kilns.
  5. Wait for Firing: A glaze fire will be scheduled based on kiln availability.
  6. Assessment Criteria: Glazes will be assessed for running, pinholing, crazing, blistering, and any risk to kilns or others’ work.
  7. Approval or Feedback: If your glaze passes, it will be added to the approved list. Otherwise, you will receive feedback for adjustments.
Note: Be prepared to possibly lose your test piece in the process.
What Is Allowed
What Is Not Allowed
Mixing Policy
Glaze Testing
Approval & Communication
For approvals, contact:
Summary
  • Only studio-approved commercial glazes are permitted — no exceptions.
  • Dry commercial glazes may only be mixed under supervision — members cannot mix on their own or off-site.
  • No homemade recipes, experimental blends, or member-sourced raw materials are allowed.
  • All glaze testing is separate from regular firings and must be placed on designated shelves.
  • Email Seth or Perla for all material approval and testing coordination.
By following these rules, we ensure a safe and respectful shared studio for everyone.
