How to Glaze
Before You Begin:
- Book the Glaze Area on Skedda before using. Max 5 hours per session. All tool use counts toward your weekly 25-hour limit.
Glazing: Step-by-Step
- Ensure your piece is bisque fired and free from dust (wipe gently with a damp sponge)
- Apply wax resist to the bottom of your piece using the small designated wax brushes provided
- Do not use your own brushes for wax resist
- Clean wax brushes: Pick wax off into trash, then rinse in HOT water
- Stir your glaze thoroughly before use — glaze ingredients settle and must be evenly mixed
- Pour glaze into a small bowl before brushing. Do not dip brushes directly into the main glaze jars
- Apply glaze evenly
- 1–3 coats depending on glaze type
- Avoid over-applying to prevent drips and runs
- Leave the bottom of the piece unglazed
- Minimum 1/4" clearance (or 1" if for glaze testing)
- Wipe foot completely clean to avoid kiln shelf damage
- Clean glaze brushes: Rinse in the sink; use hand soap if needed — black glaze may require extra scrubbing
- Label your piece clearly if it's part of glaze testing
- Place on the Glaze Fire shelf for kiln loading
Please Note:
- Make sure your glaze is studio-approved or has passed testing
- Improper glazing or unlabeled pieces may be held back from firing
What Is Allowed
- Pre-Mixed Commercial Glazes Liquid glazes sold ready-to-use by established ceramic glaze manufacturers (e.g., Amaco, Mayco, Laguna etc.).
- Studio-Approved Commercial Dry Glazes Powdered commercial dip glazes that are reconstituted under conditional supervision within the studio. These glazes must:
- Come directly from a commercial distributor
- Be mixed by or in coordination with designated studio personnel
- Receive prior approval from Seth or Perla
Please Note:
What Is Not Allowed
- Any homemade, member-formulated, or DIY glaze recipes, regardless of their source (e.g., books, online, ceramic blogs)
- Any mixture of raw glaze materials (oxides, frits, fluxes, etc.) sourced independently by members
- Any glaze materials or combinations that do not appear as a finished product in a commercial glaze bottle
- Mixing glaze powders outside the studio, including in outdoor common areas like the parking lot
Mixing Policy
- No unsupervised mixing of glaze materials is allowed, including reconstituting commercial dry dip glazes.
- Approved commercial dry glazes may be mixed only:
- Under the supervision of Seth, Perla, or another designated person
- In controlled and designated areas with proper PPE and ventilation
- Members are not permitted to bring in raw glaze materials or mix their own glazes in any studio or public area.
Glaze Testing
- All test firings must be approved and scheduled independently from regular kiln loads.
- A separate test kiln will be used when appropriate.
- The topmost studio shelves are designated for placing test pieces (bisque or glaze tests) and will be clearly labeled.
Approval & Communication
For approvals, contact:
- Seth White – seth.white@asmbly.org
- Perla Darnell – perla.darnell@asmbly.org
How to Test a Glaze
- Use a test piece (under 6" x 6" x 6") or request a vertical test tile from Asmbly (Cinco Blanco clay)
- Apply your glaze fully using the same number of coats, layering, and techniques you intend for your final work
- Leave 1" unglazed at the bottom of ceramic test pieces
- Leave 1/4"–1/2" unglazed on provided vertical test tiles
- Label the piece or tile with your name and the glaze name
- Place on the Glaze Test Shelf near the kilns
- Wait for glaze fire (scheduled based on kiln availability)
- Results will be assessed for running, crazing, blistering, or risk to kiln/kiln furniture
Please Note:
- You may lose the test piece
- Approved glazes will be added to our studio list.
Approved Glazes at Asmbly
Asmbly is a community of makers, so we encourage exploration and creativity. Below are some of the glazes approved for use in our studio. This doesn't mean we carry them all, but it means you can use them. If you are going to glaze a large piece with more layers than indicated by the instructions in the product, or if you plan to layer two different glazes in layers, please use a test tile first to be sure it will not run and stick to the kiln.
Underglazes (Mayco Brand)
- Versatile & Food Safe: Use for full coverage or in designs on clay, greenware, or bisque. Food safe when covered with a clear glaze.
- Firing Range: Cone 6 - Cone 10 (We fire to cone 6).
- Application: Shake well, apply 2-3 coats to wet clay or bisque, avoiding glaze pooling in textured areas.
- Firing: Fire to cone 04, then apply clear glaze and fire to cone 06/05 for earthenware or cone 5-10 for stoneware.
Celadon Glazes (Amaco Brand)
- Translucent & Glossy Finish: Ideal for highlighting texture on your pieces.
- Firing Range: Cone 5 - Cone 6 (Food safe).
- Available at Asmbly: Some colors available for members to use at no extra cost. Other colors can be brought in without testing.
- Application: Follow the manufacturer’s instructions for number of coats. No need to mix with other glazes.
- Fluid Colors & Effects: Great for smooth or textured pieces. Not food safe.
- Firing Range: Cone 5 - Cone 6.
- Available at Asmbly: Some samples available, but members must purchase other colors.
- Application: Test glazes first on a vertical test tile. If combining glazes, test on a tile before applying to pieces.
- Note: Results can vary due to glaze interaction, especially when layering.
- Soft Satin Feel: Semi-opaque glazes that break over texture and edges.
- Available at Asmbly: Some colors in-house for free. Members can bring in other colors without testing.
- Application: Follow the manufacturer’s instructions. No need to mix with other glazes.
- Colorful & Textured: Glass frit bursts create intricate patterns.
- Food Safety: Not 100% food safe due to potential crazing.
- Available at Asmbly: Some colors available for members to use, but members must purchase others.
- Application: Shake well and apply 2-3 coats to bisque. Stir frequently, as crystals can settle. Avoid heavy application at the bottom of pieces to prevent glaze melting onto kiln shelves.
- Note: The glass crystals bloom during firing, creating unique results each time.
Summary
- Only studio-approved commercial glazes are permitted — no exceptions
- Dry commercial glazes may only be mixed under supervision — members cannot mix on their own or off-site
- No homemade recipes, experimental blends, or member-sourced raw materials are allowed
- All glaze testing is separate from regular firings and must be placed on designated shelves
- Email Seth White (seth.white@asmbly.org) or Perla Darnell (perla.darnell@asmbly.org) for all material approval and testing coordination
