Ceramics Policy
Revision as of 22:23, 29 September 2025 by EEatx (talk | contribs) (Tools)
Introduction
Usage Areas
Tools
  • Pottery Wheels: 8 machines available: Max booking is 5 hours of time
You must book yourself as a User if you plan on sitting at a Handbuilding Table, regardless of tool booking. It is your responsibility to CHECK SKEDDA to make sure the tool is not booked. Allow for clean up time within your booked time, NOT after. Members booked in Ceramics at the same time should work together to clean and coordinate space use.
  • Handbuilding Tables: 8 Users can Book up to 5 hours of time between 4 tables (2 Users/table)
Use of the glazing area, slab roller, and extruder are included with booking of either a Pottery Wheel or Handbuilding Table. Please use these collaboratively, if multiple users need to utilize during the same time period. Be friendly and initiate conversations to best share access to these spaces.
Community Tools/Areas
  • No sanding bisque pieces inside the studio.
  • We have a Blue Ox Air filtration system installed in the studio to help cut back on particulates in the air.
    • Members are not allowed to turn the filtration system off without asking for permission.
    • If you are a staff or a volunteer, and you absolutely need to turn the filtration system off, please make sure to turn it on again before you leave.
Studio Shelves
Kilns/Kiln Room
Kiln Shelves
    • STUDENTS: we have Open hours with a Steward on Duty they can come by to retrieve their piece. Hours are listed here on the Asmbly Event Schedule
    • STUDENTS: you can coordinate a time with our kiln operators to pick up your piece by emailing kilnops@asmbly.org.
Clay & Glazes
Clays Provided in Studio
  1. Cinco Blanco
  2. Buffalo Wallow
  1. Elkhorn Red Stoneware Cone 6, $21.00/25lb bag
  2. POLAR BEAR Porcelain Cone 6, $59.25/25lb bag
  3. Roo Stoneware Cone 6, $21.50/25lb bag
  4. Speckled Turtle Cone 5-6, $21.00/25lb bag
  5. Speckled Brown Bear Cone 5-7, $24.00/25lb bag
  6. Dark Star Cone 6, $22.50/25lb bag
  7. Kota Porcelain Cone 5-6, $61.00/25bag
  8. Brown Bear Clay Cone 5-6, $23.25/25lb bag
  9. White Lightning Porcelain Cone 5-6, $53.75/25lb bag
  10. Ranger Cone 6-10, $21.25/25lb bag
  11. Big Turtle Cone 6-7, $21.00/25lb bag
  12. Sheltowee Cone 5–7, $21.00/25 lb bag
  13. Mulhollun Cone 5–7, $20.75/25 lb bag
  14. Iceman with Grog Cone 5–6, $21.50/25 lb bag
  15. White Bear Cone 5–7, $30.00/25 lb bag
  16. Tony Beaver Cone 5–7, $21.50/25 lb bag
  17. Iceman Cone 5–6, $21.25/25 lb bag
  18. River City Red Clay Cone 06-5, $22.00/25 lb bag
Glazes Provided in Studio
Amaco Celadon Line
  1. Snapdragon
  2. Tangelo
  3. Marigold
  4. Succulent
  5. Pear
  6. Sky
  7. Cobalt
  8. Mulberry
  9. Snow
  10. Obsidian
  11. Mixing Clear
Amaco Satin Matte
Satin Mattes break slightly over edges and texture and boast a soft satin feel. These glazes are formulated to be 100% mixable. Use Clear Satin to lighten color tones, Satin Black to create shades, and Satin White to create tints.
  1. Red
  2. Orange
  3. Goldenrod
  4. Moss
  5. Dark Blue
  6. Marble
  7. Black
  8. Satin Clear
Mayco Fundamentals Underglaze
  1. Fire Engine Red
  2. Orange
  3. Bright Yellow
  4. Forest Green
  5. Bright Blue
  6. Wild Violet
  7. Chocolate
  8. China White
  9. Jet Black
Dip Glazes
Mayco Jungle Gems
  1. Sassy Orange
  2. Cherry Limeade
  3. Blue Guppy
  1. Amaco Celadons, $21.00
  2. Amaco Satin Matte, $21.00
  3. Mayco Fundamentals Underglaze, $19.95
  4. Potter’s Choice, $22-$37
  5. Jungle Gems, $22.15
Kiln Check-In Procedures
Firing Sign In Process
Firing System
  3. Mid-fire Glaze or Stoneware at Cone 6 (~2200℉).
Usage Violations
    • Kiln damage
Clay Body
  1. Bisque Fire:
Glaze
  1. Glaze Fire:
Discipline/Violations Policy
