Tarkin
Revision as of 19:54, 20 November 2021 by Dannym (talk | contribs) (→‎GRAYSCALE 2D)
Setup
1. Locate Fire Extinguisher
2. Main Power Switch
3. Chiller switch
4. Locate E-STOP button
Important Terms
Machine bed
Control Panel
Material
Lightburn
Workspace
Job
User origin
Vector Cutting
Vector Engraving
Rastering
Focusing
Although the head has an adjustable tube, we do not operate by adjusting the tube. Please ensure to tube is all the way up before continuing.
Origins
Absolute coords
User origin
Camera-placed absolute coords
The machine's top axis speed is set well over 1000 mm/sec, but this is not likely to be important for rastering as this sort of speed is not commonly used. If the user's job asks for a speed higher than the machine can travel, the machine will limit its speed and proportionately scale back the % power to deliver the same energy per mm of length.
Rastering
Types of Rastering:
FILL
GRAYSCALE 2D
laser power is modulated by grayscale shade. Goal is not depth, but shading. Line intervals <0.15mm cut deeper (typically not of value, just slows down job). Grayscale works if your material can show good dynamic range (shade darkens proportionally with beam). Dynamic range of material must be investigated carefully- for example, plywood veneer may start light, burn darker with more beam, but past a certain point we cut through the veneer and briefly get a red shade from the glue and then a totally different shade from an inner ply. This would be a very poor dynamic range to allow the power to pass the point where it becomes darkest.
GRAYSCALE 3D
Same mode, but different goal. Laser power is high enough to carve into the material, depth is proportional to shade. Works with wood and acrylic. If you want to avoid creating obvious unburned areas where the shading is very light, set MIN POWER parameter >0%
DITHER/HALFTONING
If you are doing photographic raster work such as dithering/halftoning, line intervals <0.125mm will distort the image shading. The scheme of dithering is we have the original unburned surface and burned "brown" areas and nothing in between. The appearance of "shading" is created by a ratio of these, not by turning the laser intensity up and down. When raster lines overlap, the area that was intended to be bright and unburned on one line may actually be made brown by the line(s) above and below it, and the image will have distorted shading or even lost entirely in a mass of brown.
Extend space creates a slightly complicated relationship with raster speed and ultimate job time. 500mm/sec is very little extend space, >1000mm/sec requires quite a lot. For example, with a raster image only 10mm wide, running 1000mm/sec will actually take longer than 500mm/sec as it must use a wide margin of extend space to brake and reverse up to that high speed that is only used for 10mm. However, for a 1 meter wide raster, 1000mm would be substantially faster. The time wasted braking and reversing through the extend space on each pass is a fixed time per line, but the bulk of the time per line is spent on the 1 meter raster job which goes twice as fast.
The FRAME button does NOT show the bounds of Extend Space. Take care when placing clamps to the left or right of a raster. There is no easy way to see how much Extend Space will be used. The amount of Extend Space also depends on the machine parameters, which may be tweaked from time to time. In general these future improvements should reduce, not increase, the amount of Extend Space needed
Shutdown
Turn off main power
Turn off chiller
Order is NOT important
Usable
Prohibited
NO PVC
NO Polycarbonate
NO METAL
NO FOOD
The laser cutter is full of unknown toxic chemicals from other materials that may contaminate the food, and food may leave residue that contaminates the machine.
Copper Wire Flame Test
Machine Errors
WATER PROT
SYS ALARM, MACHINE PROTECTED
FRAME SLOP
Current Quirks
Table shifting when moving Z
This may affect vector engraving, producing excess depth. This depth inconsistency is more noticeable on clear acrylic, but it requires close inspection.
Currently this occurs roughly 6mm before and after any full stop.
Possible Resolution
Fixed air assist
Limit on Y size
Drive Faulting
Cone clipping
