Ceramics Policy
Revision as of 20:13, 23 December 2025 by EEatx (talk | contribs) (Blue Ox warning, 2 oz cups, fixed link to glaze page)
Introduction
Ceramics Safety & Information (CSI) is the required free class you must take before access to the studio with membership is granted. In addition to the CSI, you are required to take a Glazing Workshop class before firing glazed pieces. These are separate from the required Asmbly Orientation & Facility Tour.
Usage Areas
Tools
You must reserve time for each tool you plan to use in Skedda. It is your responsibility to CHECK SKEDDA to make sure the tool is not booked. Allow for clean up time within your booked time, NOT after. Members booked in Ceramics at the same time should work together to clean and coordinate space use. Leave yourself at least 15 minutes to clean your space and another 5 minutes of time to contribute to the cleanliness of our community studio.
  • Pottery Wheels: 8 machines available: Max booking is 5 hours of time
You must book yourself as a User if you plan on sitting at a Handbuilding Table, regardless of tool booking. It is your responsibility to CHECK SKEDDA to make sure the tool is not booked. Allow for clean up time within your booked time, NOT after. Members booked in Ceramics at the same time should work together to clean and coordinate space use. Leave yourself at least 15 minutes to clean your space and another 5 minutes of time to contribute to the cleanliness of our community studio.
  • Handbuilding Tables: 8 Users can Book up to 5 hours of time between 4 tables (2 Users/table)
    • If you will need to use an entire table, plan to book 2 half tables so that others are aware of the space available before they arrive
    • If it is not booked, you can rebook yourself as a User in Skedda up to 5 more hours
Use of the glazing area, slab roller, and extruder are included with booking of either a Pottery Wheel or 1/2 Handbuilding Table. Please use these collaboratively, if multiple users need to utilize during the same time period. Be friendly and initiate conversations to best share access to these spaces. Expect these to be crowded spaces and work efficiently!
Community Tools/Areas
  • Please clean all tools you use from the communal tools and return them CLEAN to their storage location
  • Dish racks are for SPONGES, bats and wareboards
  • Place brown paper on handbuilding tables if applying glaze at these tables
    • Glaze should be kept from contaminating the canvas and wooden table surfaces
    • NEVER turn the Blue Ox Filtration off
  • NEVER use a broom or vacuum. WATER is the best way to safely clean up clay.
  • If there is dry clay on the canvas topped tables, wet it with water and remove with a wet sponge
    • Do NOT blow clay
  • No sanding bisque pieces inside the studio.
  • We have a Blue Ox Air filtration system installed in the studio to help cut back on particulates in the air.
    • Members are NOT allowed to turn the filtration system off, it is a Policy violation
    • If you are a staff or a volunteer, and you absolutely need to turn the filtration system off, you must turn it on again before you leave.
Studio Shelves
Class/Education Shelves are clearly labeled with the Class name and date
Kilns/Kiln Room
Kiln Shelves
    • STUDENTS: we have Open hours with a Steward on Duty they can come by to retrieve their piece. Hours are listed here on the Asmbly Event Schedule
    • STUDENTS: you can coordinate a time with our kiln operators to pick up your piece by emailing kilnops@asmbly.org.
Clay & Glazes
Clays Provided in Studio
  1. Cinco Blanco
  2. Buffalo Wallow
  1. Buffalo Wallow w/ Grog
  2. Cinco Rojo
  3. Cinco Rojo w/ Grog
  4. Cone 5 Porcelain
  5. Laguna Speckled Buff
  6. Laguna B Mix and B-mix Speckled, cone 5
  7. Dark Chocolate No. 32
  1. Elkhorn Red Stoneware Cone 6
  2. POLAR BEAR Porcelain Cone 6
  3. Roo Stoneware Cone 6
  4. Speckled Turtle Cone 5-6
  5. Speckled Brown Bear Cone 5-7
  6. Dark Star Cone 6
  7. Kota Porcelain Cone 5-6
  8. Brown Bear Clay Cone 5-6
  9. White Lightning Porcelain Cone 5-6
  10. Ranger Cone 6-10
  11. Big Turtle Cone 6-7
  12. Sheltowee Cone 5–7
  13. Mulhollun Cone 5–7
  14. Iceman with Grog Cone 5–6
  15. White Bear Cone 5–7
  16. Tony Beaver Cone 5–7
  17. Iceman Cone 5–6
  18. River City Red Clay Cone 06-5
Glazes Provided in Studio-READ HOW TO GLAZE PAGE FOR PROCESS
  • All glazes provided are lead-free and food-safe.
  • Clean up glaze brushes and bowls provide for community use when finished
    • Rinse, apply soap if necessary, reshape, and return to their storage location
  • Do NOT glaze directly out of the jars, use the provided bowls to pour glaze into
    • If you have remaining glaze stored in 2 oz. cups, label and store on your personal shelf
Commercial Glaze:
The glazes we currently provide on a regular base are:
Amaco Celadon Line
  1. Snapdragon
  2. Marigold
  3. Wasabi
  4. Cobalt
  5. Mulberry
  6. Snow
  7. Obsidian
  8. Mixing Clear
Mayco Fundamentals Underglaze
  1. Fire Engine Red
  2. Orange
  3. Bright Yellow
  4. Forest Green
  5. Bright Blue
  6. Wild Violet
  7. Chocolate
  8. China White
  9. Jet Black
Dip Glazes
  2. Mayco Stoned Denim
  3. Misty Forest
  4. Floating Orange
  5. Ivory
  6. Laogai Green
These Midfire Glazes are approved for usage and firing at Asmbly, and available to purchase at Armadillo Clay or online:
  1. Amaco Celadons
  2. Amaco Satin Matte
  3. Mayco Fundamentals Underglaze
  4. Potter’s Choice
  5. Jungle Gems
  6. Speedball
  7. Laguna
  8. Spectrum
  9. Penguin
Kiln Check-In Procedures
Firing Sign In Process
Firing System
  3. Mid-fire Glaze or Stoneware at Cone 6 (~2200℉).
Usage Violations
    • Kiln damage
Clay Body
  1. Bisque Fire:
Glaze - approval of new commercial Glazes
  1. Glaze Fire:
Discipline/Violations Policy
