How to Glaze
Before You Begin: Our glazing and cleaning procedures MUST be followed if you intend to use our communal products, glazing spaces, and kiln firing.
- DO NOT dip brushes directly into glaze jars. Pour out glaze into provided bowls or cups
- Keep 2 oz plastic cups of glaze labelled and on personal shelves
- DO NOT return poured out glaze to glaze jars--these must remain uncontaminated
- DO NOT overglaze your piece--it will be rejected. 2-3 coats is all that is necessary.
- DO NOT use unapproved glazes (process listed below for approval of glazes)
- You must WAIT for each layer to fully dry before added another glaze layer
- DO use wax resist on the bottom of your piece, 1/4" if using one glaze, 1/2" if using multiple glazes. Wipe off any glaze that dripped onto this area before loading it onto the kiln shelves
Glazing: Step-by-Step
In-House Dip Glazes:
- Ensure your piece is bisque fired and free from dust BEFORE glazing (wipe gently with a damp sponge)
- Apply wax resist to the bottom and 1/2" space up sides of your piece using the small, blue designated-wax brushes provided at the glazing station
- Do not use your own brushes for wax resist
- Clean wax brushes: Pick wax off into trash, then rinse in HOT water or use provided alcohol
- Stir glaze in bucket vigorously with the brush
- scrub dense build up on the edges into the mix until you have an even consistency
- Dip for 1-2 seconds
- Rest piece on top of a glazing table or paper-covered handbuilding table as the glaze layer dries
- WAIT until the glaze is evenly dried before dipping again
- Look for an even color, discoloration means that the glaze is not dry.
- Stir glaze AGAIN scrubbing dense build up on the edges into the mix until you have an even consistency
- Dip AGAIN if coverage is not complete (1-2 seconds)
- Wipe off excess glaze from wax-resisted areas
- Place piece on HOUSE DIP GLAZE SHELF
- Prepare yourself for the wonderous, mystery of glaze
Amaco Celadon Glazes on Table in Pints:
- Apply wax resist to the bottom and 1/4" space up sides of your piece using the small designated wax brushes provided
- Stir your glaze thoroughly before use — glaze ingredients settle and must be evenly mixed
- Pour glaze into a small bowl before brushing. DO NOT DIP brushes directly into the main glaze jars
- Apply glaze evenly
- 1–3 coats depending on glaze type
- Avoid over-applying to prevent drips and runs
- Reserve 1/2" of unglazed area at the bottom of your piece if:
- thickly applied;
- if it is a fast running type of glaze (fluxes, rutiles, are examples of fast running glazes. Read the manufacturers labels and they will let you know)
- or if you are layering more than one type of glaze
- WAIT for each glaze layer to dry before applying again.
- Leave the bottom of the piece unglazed
- Minimum 1/4" clearance (or 1" if for glaze testing)
- Wipe foot completely clean to avoid kiln shelf damage
- Clean glaze brushes: Rinse in the sink; use hand soap if needed — black glaze may require extra scrubbing
- Dry and return brushes to their designated containers
- Label your piece clearly if it's part of glaze testing
- Place on the Glaze Fire shelf and use check in form for kiln shelves
Please Note:
- Make sure your glaze is studio-approved or has passed testing
- Improper glazing or unlabeled pieces will be held back from firing and will be placed in the "rejected" shelf
What Is Allowed
- Pre-Mixed Commercial Glazes Liquid glazes sold ready-to-use by established ceramic glaze manufacturers (e.g., Amaco, Mayco, Laguna etc.).
- Studio-Approved Commercial Dry Glazes Powdered commercial dip glazes that are reconstituted under conditional supervision within the studio. These glazes must:
- Come directly from a commercial distributor
- Be mixed by or in coordination with designated studio personnel
- Receive prior approval from Seth or Perla
Please Note:
What Is Not Allowed
- Any homemade, member-formulated, or DIY glaze recipes, regardless of their source (e.g., books, online, ceramic blogs)
- Any mixture of raw glaze materials (oxides, frits, fluxes, etc.) sourced independently by members
- Any glaze materials or combinations that do not appear as a finished product in a commercial glaze bottle
- Mixing glaze powders outside the studio, including in outdoor common areas like the parking lot
Mixing Policy
- No unsupervised mixing of glaze materials is allowed, including reconstituting commercial dry dip glazes.
- Approved commercial dry glazes may be mixed only:
- Under the supervision of the kiln operators, ceramics space lead, or other approved persons
- In controlled and designated areas with proper PPE and ventilation
- Members are not permitted to bring in raw glaze materials or mix their own glazes in any studio or public area.
Glaze Testing
- All test firings must be approved and scheduled independently from regular kiln loads.
- A separate test kiln will be used when appropriate.
- The topmost studio shelves are designated for placing test pieces (bisque or glaze tests) and will be clearly labeled.
Approval & Communication
For approvals, contact kilnops@asmbly.org
How to Test a Glaze
- Use a test piece (under 6" x 6" x 6") or request a vertical test tile from Asmbly (Cinco Blanco clay)
- Apply your glaze fully using the same number of coats, layering, and techniques you intend for your final work
- Leave 1" unglazed at the bottom of ceramic test pieces
- Leave 1/4"–1/2" unglazed on provided vertical test tiles
- Label the piece or tile with your name and the glaze name
- Place on the Glaze Test Shelf near the kilns
- Wait for glaze fire (scheduled based on kiln availability)
- Results will be assessed for running, crazing, blistering, or risk to kiln/kiln furniture
Please Note:
- You may lose the test piece
- Approved glazes will be added to our studio list.
Approved Glazes at Asmbly
Underglazes (Mayco Brand)
- Versatile & Food Safe: Use for full coverage or in designs on clay, greenware, or bisque. Food safe when covered with a clear glaze.
- Firing Range: Cone 6 - Cone 10 (We fire to cone 5).
- Application: Shake well, apply 2-3 coats to wet clay or bisque, avoiding glaze pooling in textured areas.
- Firing: Fire to cone 04, then apply clear glaze and fire to cone 06/05 for earthenware or cone 5-10 for stoneware.
Celadon Glazes (Amaco Brand)
- Translucent & Glossy Finish: Ideal for highlighting texture on your pieces.
- Firing Range: Cone 5 - Cone 6 (Food safe).
- Available at Asmbly: Some colors available for members to use at no extra cost. Other colors can be brought in without testing.
- Application: Follow the manufacturer’s instructions for number of coats. No need to mix with other glazes.
- Fluid Colors & Effects: Great for smooth or textured pieces. Not food safe.
- Firing Range: Cone 5 - Cone 6.
- Available at Asmbly: Some samples available, but members must purchase other colors.
- Application: Test glazes first on a vertical test tile. If combining glazes, test on a tile before applying to pieces.
- Note: Results can vary due to glaze interaction, especially when layering.
- Soft Satin Feel: Semi-opaque glazes that break over texture and edges.
- Available at Asmbly: Some colors in-house for free. Members can bring in other colors without testing.
- Application: Follow the manufacturer’s instructions. No need to mix with other glazes.
- Colorful & Textured: Glass frit bursts create intricate patterns.
- Food Safety: Not 100% food safe due to potential crazing.
- Available at Asmbly: Some colors available for members to use, but members must purchase others.
- Application: Shake well and apply 2-3 coats to bisque. Stir frequently, as crystals can settle. Avoid heavy application at the bottom of pieces to prevent glaze melting onto kiln shelves.
- Note: The glass crystals bloom during firing, creating unique results each time.
Summary
- Only studio-approved commercial glazes are permitted — no exceptions
- Dry commercial glazes may only be mixed under supervision — members cannot mix on their own or off-site
- No homemade recipes, experimental blends, or member-sourced raw materials are allowed
- All glaze testing is separate from regular firings and must be placed on designated shelves
- Email kilnops@asmbly.org for all material approval and testing coordination
