Tarkin
Setup
1. Locate Fire Extinguisher
2. Main Power Switch
3. Chiller switch
4. Locate E-STOP button
Important Terms
Machine bed
Material
Lightburn
Workspace
Job
User origin
Vector Cutting
Vector Engraving
Rastering
Focusing
Origins
Absolute coords
User origin
Camera-placed absolute coords
The machine's top axis speed is set well over 1500 mm/sec, but this is not likely to be important for rastering as this sort of speed is not commonly used. If the user's job asks for a speed higher than the machine can travel, the machine will limit its speed and proportionately scale back the % power to deliver the same energy per mm of length.
Rastering
MAX RASTER
Rastering limit is 1500mm/sec. Exceeding this will overload the drive and halt the job safely. The state can be resolved by cycling power. In general, rastering at 1500mm/sec is a good choice. This requires approx 100mm of Extend Space on either side.
Types of Rastering:
FILL
GRAYSCALE 2D
DITHER/HALFTONING 2D
Proper Line Interval
Rastering with Focus+
Determining Best Raster Power
Most jobs cutting with the "Fill" seek depth, not color change.
The goal of most grayscale or dithering is to produce the desired color change- typically the deepest color change possible. Initially, color typically deepens with more power, however, after a certain point the material may instead become lighter or change color entirely. This can happen because wood may pass a point where it chars and instead is removed cleanly. In plywood, this may occur because a veneer or ply of one type of wood is penetrated, exposing a different layer.
The possible color change varies based on the material type. Plywood gives much more dramatic color changes when pretreated with a light spraying with a contrast solution of baking soda, a drop of dish soap, and water and allowed to fully dry before lasering (this may take hours so best to do ahead of time). Some have tried boric acid solution, however, while it initially appears even blacker, it is mostly a char that comes off.
Load Lightburn project "tarkin_raster_calibration.lb2", and try with the enclosed power settings on a test piece of your material. This will operate in GRAYSCALE MODE, EVEN IF YOU ULTIMATELY INTEND TO DITHER. First, check that the LINE INTERVAL is correct, as above. If not this test result will be inaccurate.
We increase the power in 10 steps from left to right, and show the color change as power increases. Although done in grayscale, this calibration applies equally well to all dithering modes as well.
[TBD: picture]
Determine which square has the desired color change. In this case, it is 70%. Note the speed and power used. By multiplying the power by 0.7, this will be the deepest shade created by the blackest black in grayscale mode. In raster mode, this will be the color of the burn marks and there will be no partial shading.
This assumes raster speed is already at a maximum- either the 1500mm/sec machine limit, or simply that the raster is not very wide and the extra Raster Extend Space needed for higher speeds means the higher speeds are not running any faster. If it is possible to run faster, it is desirable to first scale up the raster speed proportionately. In this example, you would divide the speed by 0.7. However, the max raster speed limit still applies.
It is possible to "get lost" in finding the correct power and end up in a depth-cutting mode. In the below example, [TBD], initially increases in power darkens the burn. However, as the cut deepens, it removes the outer veneer layer, then we see glue, and then interior plys of a different color entirely. This is generally not a functional place to be, we have totally passed the conventional range. The baking soda contrast-enhancing solution will only do its job if we don't cut through it entirely.
Extend space creates a slightly complicated relationship with raster speed and ultimate job time. 500mm/sec is very little extend space, 1500mm/sec requires 100mm on either side. For example, with a raster image only 25mm wide, running 1500mm/sec will actually take longer than 500mm/sec as it must use a wide margin of extend space to brake and reverse up to that high speed that is only used for 25mm. However, for a 1 meter wide raster, 1500mm would be substantially faster. The time wasted braking and reversing through the extend space on each pass is a fixed time per line, but the bulk of the time per line is spent on the 1 meter raster job which goes twice as fast.
Shutdown
Turn off main power
Turn off chiller
Order is NOT important
Usable
Plywood quality and "Patches"
Prohibited
NO PVC
NO Polycarbonate
NO METAL
NO FOOD
Copper Wire Flame Test
Machine Errors
The machine is currently running a job, or the panel was navigated to a menu screen that cannot accept jobs, or the machine is off. However, about 5% of the time the jobs do get this error from a network prob that is not well understood, but the job simply needs to be re-sent.
WATER PROT
SYS ALARM, MACHINE PROTECTED
Likely causes:
FRAME SLOP
However, a better alternative would be to download the current Tarkin machine profile here [TBD] and load that on to your machine. This has all the parameters that will allow you to get accurate time predictions in the Preview window.
Current Quirks
Table shifting when moving Z
This may affect vector engraving, producing excess depth. This occurs roughly 6mm before and after full stops. This depth inconsistency is more noticeable on clear acrylic, but usually would only be noticeable upon close inspection.
Possible Resolution
Fixed air assist
Expected resolution
Limit on Y size
Drive Faulting
If the motor drive capabilities are exceeded and a drive fault occurs. the machine will stop immediately, and throw a generic "System Protected" error, the same as if the lid is open. This error might occur if excess rastering speed is specified (>1500mm/sec?) or crashing the head into the material, clamp, or jig. Of note, the problem axis cannot be jogged with the control panel, even though the panel coordinates increment. The other axis moves normally. This fault is resolved by cycling Main Power on Tarkin and letting it rehome. If this fault occurs due to rastering or any case other than crashing the head, please contact workshop with details about settings and, if possible, a copy of the Lightburn project with the settings that led to the fault.
Cone clipping
