Tarkin
Tarkin is the new large-format laser cutter in the space. It's a custom-built laser cutter based on an RF CO2 10.6um laser and the latest in C-rail linear motion system with a Ruida RDC6445G controller running Lightburn software. It features 225W of power on a 1.6M x 1.0 M (63"x39") cutting bed, powered Z, 8MP alignment camera, and air assist.
Setup
1. Locate Fire Extinguisher
2. Main Power Switch
3. Chiller switch
4. Locate E-STOP button
Important Terms
Machine bed
Material
Lightburn
Workspace
Job
User origin
Vector Cutting
Vector Engraving
Rastering
Focusing
Origins
Absolute coords
User origin
Camera-placed absolute coords
The machine's top axis speed is set well over 1500 mm/sec, but this is not likely to be important for rastering as this sort of speed is not commonly used. If the user's job asks for a speed higher than the machine can travel, the machine will limit its speed and proportionately scale back the % power to deliver the same energy per mm of length.
Rastering
MAX RASTER
Rastering limit is 1500mm/sec. Exceeding this will overload the drive and halt the job safely. The state can be resolved by cycling power. In general, rastering at 1500mm/sec is a good choice. This requires approx 100mm of Extend Space on either side.
Types of Rastering:
FILL
GRAYSCALE 2D
DITHER/HALFTONING 2D
Proper Line Interval
Rastering with Focus+
Determining Best Raster Power
Most jobs cutting with the "Fill" seek depth, not color change.
The goal of most grayscale or dithering is to produce the desired color change- typically the deepest color change possible. Initially, color typically deepens with more power, however, after a certain point the material may instead become lighter or change color entirely. This can happen because wood may pass a point where it starts to disintegrate into char and instead is removed entirely. In plywood, this may even reverse the color deepening trend because a veneer or ply of one type of wood is penetrated, exposing a different layer.
The possible color change varies based on the material type. Plywood gives much more dramatic color changes when pretreated with a light spraying with a contrast solution of baking soda, a drop of dish soap, and water and allowed to fully dry before lasering (this may take hours so best to do ahead of time). Some have tried boric acid solution, however, while it initially appears even blacker, it is mostly a char that comes off.
Are there other speeds? Yes. but we are already speed-limited, not power-limited. 750mm/sec and 4% power should yield a virtually identical burn, but this job will take twice as long so there is no clear value to it.
Rather, let's look at the original bitmap image itself. Select the image, then Tools->Adjust Image. There are sliders, dithering methods, and live, zoom-able preview of the image. Any changes here are DYNAMIC- it keeps the original bitmap and a list of these adjustments, rather than overwriting the bitmap with the adjusted image and forgetting the settings that adjusted it. If you OK out of this window, the design workspace shows the adjusted image. If you later enlarge the image size in the workspace, the line interval won't widen with it, it will be re-rendered with more lines, not wider intervals. If you return to Adjust Image, the original is still there along with all the adjustment sliders and dithering where you last set them.
This allows you to see what sort of detail the rastering will be able to do. We should not change our line interval, that will NOT add detail, just create overlap that breaks dithering by collapsing the dynamic range. If the detail cannot render, and we are already using the best focus, the only choice is to increase the image size to see the detail. But we contrast, brightness, gamma, and radius enhancement will enhance greatly. There is no fixed formula for this, it works off the exposure settings of the original image along with looking for the the specific detail you want to make most prominent. Adjust Image settings apply only to the selected image, not necessarily the entire Image Layer which may have multiple images in it. and are NOT saved in the Materials Library entry. The Materials Library only stores the speed, %power, dithering type, and line interval. The Adjust Image settings used on each image will save in the project, however.
Extend space creates a slightly complicated relationship with raster speed and ultimate job time. 500mm/sec is very little extend space, 1500mm/sec requires 100mm on either side. For example, with a raster image only 25mm wide, running 1500mm/sec will actually take longer than 500mm/sec as it must use a wide margin of extend space to brake and reverse up to that high speed that is only used for 25mm. However, for a 1 meter wide raster, 1500mm would be substantially faster. The time wasted braking and reversing through the extend space on each pass is a fixed time per line, but the bulk of the time per line is spent on the 1 meter raster job which goes twice as fast.
Shutdown
Turn off main power
Turn off chiller
Order is NOT important
Usable
Plywood quality and "Patches"
Prohibited
NO PVC
NO Polycarbonate
NO METAL
NO FOOD
Copper Wire Flame Test
Machine Errors
The machine is currently running a job, or the panel was navigated to a menu screen that cannot accept jobs, or the machine is off. However, about 5% of the time the jobs do get this error from a network prob that is not well understood, but the job simply needs to be re-sent.
WATER PROT
SYS ALARM, MACHINE PROTECTED
Likely causes:
FRAME SLOP
Current Quirks
Table shifting when moving Z
By design, the motion controller should scales back the beam power when it is not able to achieve the specified velocity, due to acceleration limitations. However, the Ruida is not scaling back enough and can deliver excess power where vectors start, stop, or sharply corner or perform very tight curves. This appears to be a limitation of the Ruida controller and has no immediate way to correct.
This may affect vector engraving, producing excess depth. This occurs roughly 6mm before and after full stops. This depth inconsistency is more noticeable on clear acrylic, but usually would only be noticeable upon close inspection.
This issue does not exist when rastering, which the controller always runs in constant-velocity mode
Possible Resolution
Fixed air assist
Expected resolution
Limit on Y size
Drive Faulting
Cone clipping
