Module:Format link
Documentation for this module may be created at Module:Format link/doc
-------------------------------------------------------------------------------- -- Format link -- -- Makes a wikilink from the given link and display values. Links are escaped -- with colons if necessary, and links to sections are detected and displayed -- with " § " as a separator rather than the standard MediaWiki "#". Used in -- the {{format link}} template. -------------------------------------------------------------------------------- local libraryUtil = require('libraryUtil') local checkType = libraryUtil.checkType local checkTypeForNamedArg = libraryUtil.checkTypeForNamedArg local mArguments -- lazily initialise [[Module:Arguments]] local mError -- lazily initialise [[Module:Error]] local yesno -- lazily initialise [[Module:Yesno]] local p = {} -------------------------------------------------------------------------------- -- Helper functions -------------------------------------------------------------------------------- local function getArgs(frame) -- Fetches the arguments from the parent frame. Whitespace is trimmed and -- blanks are removed. mArguments = require('Module:Arguments') return mArguments.getArgs(frame, {parentOnly = true}) end local function removeInitialColon(s) -- Removes the initial colon from a string, if present. return s:match('^:?(.*)') end local function maybeItalicize(s, shouldItalicize) -- Italicize s if s is a string and the shouldItalicize parameter is true. if s and shouldItalicize then return '<i>' .. s .. '</i>' else return s end end local function parseLink(link) -- Parse a link and return a table with the link's components. -- These components are: -- - link: the link, stripped of any initial colon (always present) -- - page: the page name (always present) -- - section: the page name (may be nil) -- - display: the display text, if manually entered after a pipe (may be nil) link = removeInitialColon(link) -- Find whether a faux display value has been added with the {{!}} magic -- word. local prePipe, display = link:match('^(.-)|(.*)$') link = prePipe or link -- Find the page, if it exists. -- For links like [[#Bar]], the page will be nil. local preHash, postHash = link:match('^(.-)#(.*)$') local page if not preHash then -- We have a link like [[Foo]]. page = link elseif preHash ~= '' then -- We have a link like [[Foo#Bar]]. page = preHash end -- Find the section, if it exists. local section if postHash and postHash ~= '' then section = postHash end return { link = link, page = page, section = section, display = display, } end local function formatDisplay(parsed, options) -- Formats a display string based on a parsed link table (matching the -- output of parseLink) and an options table (matching the input options for -- _formatLink). local page = maybeItalicize(parsed.page, options.italicizePage) local section = maybeItalicize(parsed.section, options.italicizeSection) if (not section) then return page elseif (not page) then return mw.ustring.format('§ %s', section) else return mw.ustring.format('%s § %s', page, section) end end local function missingArgError(target) mError = require('Module:Error') return mError.error{message = 'Error: no link or target specified! ([[' .. target .. '#Errors|help]])' } end -------------------------------------------------------------------------------- -- Main functions -------------------------------------------------------------------------------- function p.formatLink(frame) -- The formatLink export function, for use in templates. yesno = require('Module:Yesno') local args = getArgs(frame) local link = args[1] or args.link local target = args[3] or args.target if not (link or target) then return missingArgError('Template:Format link') end return p._formatLink{ link = link, display = args[2] or args.display, target = target, italicizePage = yesno(args.italicizepage), italicizeSection = yesno(args.italicizesection), categorizeMissing = args.categorizemissing } end function p._formatLink(options) -- The formatLink export function, for use in modules. checkType('_formatLink', 1, options, 'table') local function check(key, expectedType) --for brevity checkTypeForNamedArg( '_formatLink', key, options[key], expectedType or 'string', true ) end check('link') check('display') check('target') check('italicizePage', 'boolean') check('italicizeSection', 'boolean') check('categorizeMissing') -- Normalize link and target and check that at least one is present if options.link == '' then options.link = nil end if options.target == '' then options.target = nil end if not (options.link or options.target) then return missingArgError('Module:Format link') end local parsed = parseLink(options.link) local display = options.display or parsed.display local catMissing = options.categorizeMissing local category = '' -- Find the display text if not display then display = formatDisplay(parsed, options) end -- Handle the target option if present if options.target then local parsedTarget = parseLink(options.target) parsed.link = parsedTarget.link parsed.page = parsedTarget.page end -- Test if page exists if a diagnostic category is specified if catMissing and (mw.ustring.len(catMissing) > 0) then local title = nil if parsed.page then title = mw.title.new(parsed.page) end if title and (not title.isExternal) and (not title.exists) then category = mw.ustring.format('[[Category:%s]]', catMissing) end end -- Format the result as a link if parsed.link == display then return mw.ustring.format('[[:%s]]%s', parsed.link, category) else return mw.ustring.format('[[:%s|%s]]%s', parsed.link, display, category) end end -------------------------------------------------------------------------------- -- Derived convenience functions -------------------------------------------------------------------------------- function p.formatPages(options, pages) -- Formats an array of pages using formatLink and the given options table, -- and returns it as an array. Nil values are not allowed. local ret = {} for i, page in ipairs(pages) do ret[i] = p._formatLink{ link = page, categorizeMissing = options.categorizeMissing, italicizePage = options.italicizePage, italicizeSection = options.italicizeSection } end return ret end return p
