Module:Transclusion count
Documentation for this module may be created at Module:Transclusion count/doc
local p = {} function p.fetch(frame) local template = nil local return_value = nil -- Use demo parameter if it exists, otherswise use current template name local namespace = mw.title.getCurrentTitle().namespace if frame.args["demo"] and frame.args["demo"] ~= "" then template = frame.args["demo"] elseif namespace == 10 then -- Template namespace template = mw.title.getCurrentTitle().text elseif namespace == 828 then -- Module namespace template = (mw.site.namespaces[828].name .. ":" .. mw.title.getCurrentTitle().text) end -- If in template or module namespace, look up count in /data if template ~= nil then namespace = mw.title.new(template, "Template").namespace if namespace == 10 or namespace == 828 then template = mw.ustring.gsub(template, "/doc$", "") -- strip /doc from end local index = mw.ustring.sub(mw.title.new(template).text,1,1) local status, data = pcall(function () return(mw.loadData('Module:Transclusion_count/data/' .. (mw.ustring.find(index, "%a") and index or "other"))) end) if status then return_value = tonumber(data[mw.ustring.gsub(template, " ", "_")]) end end end -- If database value doesn't exist, use value passed to template if return_value == nil and frame.args[1] ~= nil then local arg1=mw.ustring.match(frame.args[1], '[%d,]+') if arg1 and arg1 ~= '' then return_value = tonumber(frame:callParserFunction('formatnum', arg1, 'R')) end end return return_value end -- Tabulate this data for [[Wikipedia:Database reports/Templates transcluded on the most pages]] function p.tabulate(frame) local list = {} for i = 65, 91 do local data = mw.loadData('Module:Transclusion count/data/' .. ((i == 91) and 'other' or string.char(i))) for name, count in pairs(data) do table.insert(list, {mw.title.new(name, "Template").fullText, count}) end end table.sort(list, function(a, b) return (a[2] == b[2]) and (a[1] < b[1]) or (a[2] > b[2]) end) local lang = mw.getContentLanguage(); for i = 1, #list do list[i] = ('|-\n| %d || [[%s]] || %s\n'):format(i, list[i][1]:gsub('_', ' '), lang:formatNum(list[i][2])) end return table.concat(list) end return p
