Tarkin
Tarkin is the new large-format laser cutter in the space. It's a hot-rod custom-built laser cutter based on an RF CO2 10.6um laser and the latest in C-rail linear motion system with a Ruida RDC6445G controller running Lightburn software. It features 225W of power on a 1.6M x 1.0 M (63"x39") cutting bed, powered Z, 16MP alignment camera, and air assist.
Setup
1. Locate Fire Extinguisher
2. Main Power Switch
3. Chiller switch
4. Locate E-STOP button
Important Terms
Machine bed
Material
Lightburn
Workspace
Job
User origin
Vector Cutting
Vector Engraving
Rastering
Fill
Focusing
Origins
Absolute coords
User origin
Camera-placed absolute coords
Rastering
MAX RASTER
Types of Rastering:
FILL
GRAYSCALE 2D
DITHER/HALFTONING 2D
Rastering with Focus+
Shutdown
Turn off main power
Turn off chiller
Order is NOT important
Usable
Plywood quality and "Patches"
Prohibited
NO PVC
NO Polycarbonate
NO PINE OVER 3/8"
Pine- as either lumber or cheap plywood- is very resinous, more difficult to cut, and much more prone to form a coal that smolders or catches fire during or after cutting. While Tarkin has been uniquely successful at cutting wood and plywood well over 1/2" (6mm), pine in any form has consistently failed in flames in anything past 3/8" (9mm) and is prohibited. Spruce and fir are not pine.
NO METAL
NO FOOD
Copper Wire Flame Test
Machine Errors
Causes:
WATER PROT
SYS ALARM, MACHINE PROTECTED
Likely causes:
FRAME SLOP
Current Quirks
Table shifting when moving Z
Fixed air assist
Expected resolution
Drive Faulting
Cone clipping
