Openpath
Asmbly uses OpenPath smart readers for building access control (door locks). This system uses a smartphone app as a primary authentication mechanism, so you don't need to use a key fob or badge anymore.
To set up an OpenPath credential on your smartphone, click on the link in the OpenPath invitation email. If you haven't received an invitation, you can install the app but can't set up access to Asmbly.
For Users
Subscriber access is granted on successful completion of all pre-requisites for membership:
- Purchased a subscription in Neon
- Signed the subscription agreement and liability waiver
- Completed the facility and safety tour if joined later than July 1 2021
As of now (Aug 2021) OpenPath invites are sent in batches, so it could take up to 24 hours to receive an invitation after completing all your prerequisites. In the future the process will be speedier.
If your subscription lapses in Neon, your OpenPath access will be suspended. It will be re-enabled when you renew.
For Administrators
Our panel has a dual-voltage accessory power supply, which takes up a fair amount of space and we don't actually need since all our lock hardware is 24V. We could fit bigger backup batteries if we removed the 12V supply parts.
| Color | Signal |
| Brown / Brown-White | Ground |
| Orange / Orange-white | +V |
| Blue | Data+ |
| Blue-white | Data- |
| Green / Green-White | Door position contact (NC) |
