Rikon 10-325 Bandsaw
Revision as of 03:06, 30 September 2021 by Jon (talk | contribs) (Created page with "The '''Rikon 14-inch Deluxe Bandsaw model 10-325''' features two speeds (1445 and 2950 ft/min), a 13-inch resaw capacity and a 1-1/2 HP 110/220V motor. It accepts 1/8-inch to...")
The Rikon 14-inch Deluxe Bandsaw model 10-325 features two speeds (1445 and 2950 ft/min), a 13-inch resaw capacity and a 1-1/2 HP 110/220V motor. It accepts 1/8-inch to 3/4-inch blade width. Changeout is easy with a hinged blade guard that provides 2 inches of access.
This saw is usually set up for resaw.
Do not cut metal with this tool. This bandsaw is to be used for wood only. For metal, use the Central Machinery 4x6-inch Metal-Cutting Bandsaw.
Features Include:
  • Quick-release blade tension
  • 2 speeds: 1445/2950 ft/min
  • Hinged blade guard with sight window
  • Large 16-by-21-1/2-inch work table
