Big CNC
Max Z height is approx 7.5" from nut to spoilboard, but this does vary as spoilboard is added or removed. Note that the max usable stock height will typically need room for your bit to go on top of it
Checklist
Before I Start
- Mount the bit
- Unrack & Home
- Switch on Dust Collection
When I'm done
Tooling
While there's often an assortment of tools to be found around the space, regular users will want to purchase their own router bits.
