CR-10S
Revision as of 04:05, 27 June 2022 by Pearlgreymusic (talk | contribs) (Pearlgreymusic moved page CR-10 to CR-10S)
The Creality CR-10S is a 3D printer at the space. Because it has a Bowden extruder setup, it is NOT recommended to use flexible filaments (such as TPU) with the CR-10. This CR-10S is modified, so it may have specifications different from the stock specifications outlined in the manual. List of known modifications TBA.
| Status | Active |
| Video Feed | Unknown |
| Manufacturer | Prusa |
| Model | i3 MK3S+ |
| Nozzle Size | 0.4mm |
| Nozzle Type | Brass(?) |
| Nozzle Count | 1 |
| Filament Size | 1.75mm |
| Print Volume | 300 x 300 x 400mm |
| Max Bed Temperature | 90(?)C |
| Max Nozzle Temperature | 230(?)C |
| Max Print Speed | 60(?)mm/s |
| Extruder Type | Bowden |
| Manual | Unknown |
| Network Address | Unknown |
