Flashforge Creator Pro
ClassWarningIcon.png Members must complete the 3D Printing Class before using this tool
The Flashforge Creator 2 Pro is a fully enclosed 3D Printer with independent dual extruders (IDEX). The IDEX setup uniquely allows this printer to extrude both nozzles at the same time in the following modes:
  • Mirror Mode - Two objects horizontally mirrored
  • Duplicate Mode - Two objects identical in orientation
  • Multimaterial Mode - Print one object using multiple materials
  • Soluble Support Mode - Print one object using one main material, and support material that washes away with a liquid
Unknown Name (Creator 2 Pro)
Status Working, Not Set Up
Manufacturer Flashforge
Model Creator 2 Pro
Nozzle Size 0.4mm
Nozzle Type Brass(?)
Nozzle Count 2 (IDEX)
Filament Size 1.75mm
Print Volume 200 x 148 x 150mm
Max Bed Temperature 120(?)C
Max Nozzle Temperature 240(?)C
Max Print Speed 100(?)mm/s
Extruder Type Direct
Manual Unknown
Control Interface Unknown
Network Address Unknown
This tool is owned by Russell Miller and hosted at Asmbly for members to use. Please contact the workshop committee if maintenance is required.
