Flashforge Creator Pro
Revision as of 03:55, 28 June 2022 by Pearlgreymusic (talk | contribs) (Pearlgreymusic moved page Flashforge Creator 2 Pro to Flashforge Creator Pro)
The Flashforge Creator 2 Pro is a fully enclosed 3D Printer with independent dual extruders (IDEX). The IDEX setup uniquely allows this printer to extrude both nozzles at the same time in the following modes:
- Mirror Mode - Two objects horizontally mirrored
- Duplicate Mode - Two objects identical in orientation
- Multimaterial Mode - Print one object using multiple materials
- Soluble Support Mode - Print one object using one main material, and support material that washes away with a liquid
| Status | Working, Not Set Up |
| Video Feed | Unknown |
| Manufacturer | Flashforge |
| Model | Creator 2 Pro |
| Nozzle Size | 0.4mm |
| Nozzle Type | Brass(?) |
| Nozzle Count | 2 (IDEX) |
| Filament Size | 1.75mm |
| Print Volume | 200 x 148 x 150mm |
| Max Bed Temperature | 120(?)C |
| Max Nozzle Temperature | 240(?)C |
| Max Print Speed | 100(?)mm/s |
| Extruder Type | Direct |
| Manual | Unknown |
| Network Address | Unknown |
This tool is owned by Russell Miller and hosted at Asmbly for members to use. Please submit a problem report if maintenance is required.
