Electrical Infrastructure
Asmbly's facility is composed of three separate units of 9701 Dessau Road building 3, each of which is equipped with its own "light commercial" 200A 3-phase 120/208V service. Our meters and outdoor disconnects are on the south side of the building around the corner from the laser exhausts.
- The 303 service feeds 200A panel L4 via a main breaker outside. L4 feeds subpanel L3 via a 100A branch circuit breaker.
- The 304 service has a 200A fused disconnect feeding a 200A main panel outside (SP6), which feeds subpanels L2 (via a switch disconnect SW1) and L5 via 100A branch circuit breakers. L5 feeds L6 via a ??? A branch circuit breaker.
- The 306 service has a 200A fused disconnect feeding panel L7 (in the multipurpose room). L7 feeds subpanel L8 via a 100A branch circuit breaker.
Restated in terms of panels:
| Panel | Location | Supply | Areas & Machines Directly Powered |
| SP6 | Outside | 304 Fused Disconnect | |
| L1 | Unused (Stored in NE closet) | N/A | |
| SW1 | Main shop, South wall, east side | SP6 100 A branch circuit | |
| L2 | Main shop, North wall | SW1 | Metal Shop, Air Compressor (3ø supply) |
| L3 | Main shop, South wall, east side | L4 100A branch circuit | Wood Shop, incl. Planer, Jointer, Drill Press, Router, Sander, Band Saws;
Electronics Room |
| L4 | Main shop, South wall, east side | 303 Main Breaker | AC/Heating Units |
| L5 | Main shop, South wall, west side | SP6 100A branch circuit | Wood Shop, incl. Saw Stop, Chop Saw |
| L6 | Main shop, South wall, west side | L5 ??? A branch circuit | Wood Shop, incl. Dust Collector (?), Small CNC, Sanding Table |
| L7 | Multipurpose Room | 306 Fused Disconnect | Laser Room, 3D Printing Room, Textiles, Multipurpose Room, Lobby |
| L8 | Main shop, West wall | L7 100A branch circuit | Large CNC, Part of Fiber Laser |
