Delta 31-484 Spindle Sander
Revision as of 16:23, 15 March 2023 by Jon (talk | contribs)
To change the spindle:
  1. Remove the black table insert by lifting it out.
  2. At the rear of the machine, lift the two black handles to remove the access panel.
  3. Use the two wrenches hanging on the left side of the machine to loosen the spindle. One wrench holds the spindle seat in place, the other loosens the spindle.
  4. Unscrew the spindle by hand and store it upright in the spindle trays on either side of the machine.
  5. Screw in the new spindle and tighten using the wrenches. Hang the wrenches back on the left side when you’re finished with them.
  6. Choose a suitable table insert (hanging on the left side of the machine) for the spindle’s size and place it in the table, aligning the notch on the right side of the insert. Make sure to choose a table insert that will accommodate the angle you plan to tilt the spindle to.
