PolyPrinter 229
Revision as of 01:29, 5 October 2021 by Jon (talk | contribs)
The Polyprinter 229 is fast, reliable and straightforward to use. 4mm nozzle, 9"x9"x9" (229mm) volume.
ClassWarningIcon.png Members must complete the 3D Printing Class before using this tool
Critical Info!
  • Do NOT use metal tools on the Bed
  • Avoid touching the plate with your fingers. Skin oil can affect performances.
  • Only use Polyprinter brand filament reels
PDF manual
Asmbly has a growing fleet of FDM and SLA printers, including a Prusa XL with 5 toolheads to allow for printing up to a 12" cube with 5 different filaments.
New 3DP policies effective 10/26/2023:
  • Skedda hours booked in the 3DP categories will not count against your 25 hr/wk allotment
  • Users should now book the entire print time on Skedda, instead of setup time only
  • Users may not utilize more than 2 printers simultaneously
New 3DP policies for resin printers effective 05/14/2024:
  • Users should now reserve the resin printers for the entire duration of the setup, printing process, and the time needed to remove the print from the print bed. This policy ensures that the printer is ready for the next booking and eliminates the risk of damage to your part by requiring someone else to remove your prints.
Printers currently available for members to use are listed below.
