Manual Milling Class
Revision as of 02:49, 5 October 2021 by Jon (talk | contribs)
This class focuses on using the Rong-Fu 45 Vertical Mill as well as a lot of other tools (DO-All Bandsaw, Sandblaster, Belt Sander, and grinder). It is a required prerequisite for the Tormach class. Each student will leave the class with a key chain made in the class.
Please review the how to indicate a vise and the climb vs conventional milling video located at the link below before the class.
http://tomstechniques.com/instructional-videos/milling/
Syllabus
  • Safety
  • Parts of the Mill
  • How to indicate a vise
  • How to calculate proper machine RPM
  • Difference between climb and conventional milling
  • How to square a part
  • How to layout a semi precise part with Dykem fluid and calipers
  • How to center drill, drill, and counter bore
  • How to mill a pocket
  • How to use the Do-All Band-saw
  • How to use the sandblaster
  • How to make a leather insert on the Laser
This is an active class at Asmbly. If you can't find an upcoming session in the Class Schedule, email education@asmbly.org for more information.
